King's Cross to Waterloo
ricoblade
28 Sep 2015
Hi All - What's the quickest way to get from King's Cross to Waterloo please? I have a trip in a few weeks' time where I'd like to make a "sporty" connection at Waterloo if possible.
I'm currently thinking Victoria Line via the old ticket hall at King's Cross then changing at either Euston or Warren Street onto the Northern Charing Cross branch.
Thanks in advance.
Easiest is old ticket hall at Kings Cross, Victoria line, cross platform at Oxford Circus to Bakerloo.
At Kings Cross escalators are at front of train, but try and walk about two thirds of platform at either KX or OC as need to be nearer back for quick exit at Waterloo.
If you can use the rush hour exit (turn right in ticket hall at Waterloo to subway under platforms), then go up stairs to platform (but this is closed evenings etc)
antharro
20 Dec 2006
Agree with the advice given, although it depends if there's a particular part of Waterloo you need to get to. For example, the walk between the Jubilee ticket hall and the Bakerloo line isn't short (especially if the walkways are out of use), so that may be a factor.
Flinn Reed
8 Dec 2017
Could also consider using Thameslink from St Pancras to London Bridge, then change for Southeastern to Waterloo East? KCSP and Waterloo are both major tube stations with long corridors etc, so may save time getting to/from the platforms.
sh24
28 Sep 2023
That will be far slower, not least due to frequency.
Agree - old ticket hall, Victoria to Bakerloo at Oxford Circus and get on the 4th-5th car of the Bakerloo train for speediest exit.
greyman42
14 Aug 2017
If your train from Waterloo calls at Vauxhall, you can get the Victoria line to Vauxhall from Kings Cross.
Hadders
27 Apr 2011
Fastest way is Victoria Line to Oxford Circus and change to the Bakerloo Line. I'd expect to do a 'sporty connection' in little more than 15 minutes, if you position yourself appropriately.
If on a tight budget and wanting to avoid the use of LU for any particular ticketing reason, then it is worth considering.
But if time is important (as mentioned in the original post), then absolutely not.
15 mins is elite level sportiness!
From exiting platform at KX, assuming walking down the escalators, a Vic Line train just pulling up as you enter the platform, an unhindered run to Oxford Circus, a Bakerloo just pulling in as you walk across to that platform, an unhindered run to Waterloo, and walking up the escalators / stairs (if you know the right platform) at Waterloo and onto the platform I reckon is 16/17 minutes. But you need to know exactly where you are going, and a lot has to go right for that time!
I usually allow 25.
To the OP - if your train from Waterloo also calls at Vauxhall, then it is quicker to stay on the Victoria line to Vauxhall and catch your service there. Again allow 25 mins platform to platform.
Hadders
27 Apr 2011
To do it that fast everything does need to go right and you need to walk very fast!
In sport you win some and you lose some so don't rely on it always being that fast.
Which is the Old ticket hall at King's Cross? Is it signposted?
It was the one built under the surface, reached by steps, just in front of main train shed.
Cross the concourse and go outside and look for stairs down. Not signposted until the stairs, as the signage directs you to the new bigger ticket halls (which are indirect routing and lot longer walk as they were built where space was available, not in a straight line)
rebmcr
15 Nov 2011
St Neots
The one with the semicircular gateline, grey/beige decor, and a plaque memorialising the Kings Cross fire.
The 'new' ticket hall is cavernous and has straight gatelines and white ambiance.
Recessio
4 Aug 2019
Perfect thanks, I know which one you mean from that description!
My commute involves going Waterloo to King's Cross, so knowing the best route through the stations from this thread has been very helpful. Thanks all
DelW
15 Jan 2015
My mental rule at King's Cross underground is "if in doubt, follow the signs for Met / Circle / H&C" which always seem to get me to the southern concourse.
ricoblade
28 Sep 2015
Thanks All - I made the journeys this week and all went smoothly. I timed it on the way back and it was 23 minutes from exiting the front of the train at mainline Waterloo to arriving on the mainline concourse at King's Cross. I probably had 5 minutes of waiting for tubes at Waterloo and Oxford Circus.
TT-ONR-NRN
30 Dec 2016
Worcester
It’s often the rubbish Bakerloo line frequency that can ruin this. Arriving at Oxford Circus to see the heart-sinking “four minutes.” Slow trains too.
Railguy1
6 Apr 2016
Horses for courses…but I commute weekly on the Bakerloo line in that area and generally much prefer it to the Jubilee line because it is usually less crowded. When going north towards Baker Street from the south, interchange at Green Park can also be an absolute nightmare compared to cross platform interchange at Oxford Circus. When leaving work at Vauxhall, I will also often go for a nice walk to Embankment or Waterloo and avoid the large crowds at Westminster.
As an aside, I remember talking to a colleague about walking to Embankment (25 minutes) instead of going to my nearby station Vauxhall and he seemed baffled as the “Victoria line didn’t go to embankment”. We are pretty lucky in Central London to have so many routes to take!
Julia
19 Jun 2011
If you're coming into Kings Cross on a slower train from the north, and you see a 1-2 minute connection towards Moorgate as you pull into Finsbury Park, might be worth taking that and switching to the Victoria line at Highbury - gets you to Waterloo with all cross-platform changes.
