Can anyone advise if using the Picadilly Line to get from Kings Cross to Heathrow Terminal 2 is a bad idea?
I only ask because I cannot get Google Maps to suggest this route however hard I try. (The Tfl app also seems to avoid this route). Even if I select "Fewer Transfers" it won't suggest this route, even though a quick glance at an Underground map shows that the Picadilly line runs from Kings Cross to Heathrow without the need to change. Is it really such a bad idea? I won't be in too much of a hurry, and will be pulling a carry-on sized wheely case, so I thought I might save some money compared to taking the Heathrow Express.
If I ignore suggestions via the Heathrow Express then Google seems determined to make me take the Elizabeth line. For example, take the Picadilly Line to Holborm, then Central Line to Ealing Broadway, and Elizabeth Line to Heathrow. All suggestions seem to involve at least two changes, which seems complicated compared to just taking the Picadilly Line all the way. What's the problem? Are there fewer trains on the Picadilly Line? Does it take substantially longer?
Any advice appreciated.
