Kings Cross to Donny/Scunthorpe advice
6 Nov 2016
Travelling from the East into Heathrow due Heathrow 19:00 Friday 27/1/17. Probably scope for delay as involves a flight change. Need to get from Kings Cross to Scunthorpe or Doncaster would do. Can get an advance for £13 but if I miss the train I’m snookered. Anybody offer advice that bags a cheap ride but maybe has some flexibility? THX.
higthomas
27 Nov 2012
Have a google of Doncaster's power hour. It seems to allow you an hour either side of advanced tickets there. That would give you a two hour window, which should be enough...
Haywain
3 Feb 2013
It was, and it is no longer in place.
Sent from my SM-G800F using Tapatalk
greatkingrat
20 Jan 2011
Advances will be the cheapest option, even if you end up buying two advances for different trains to give you a backup option.
CyrusWuff
20 May 2013
The last train from Kings Cross with a connection to Scunthorpe is at 2035, which is much too early for a connection out of a longhaul flight into Heathrow.
The earliest train I'd consider is the 2200 Kings Cross to Doncaster (final destination is Newcastle), but YMMV.
bb21
Emeritus Moderator
4 Feb 2010
At that sort of arrival time, your best bet is a night in a cheap hotel and a suitable Advance the following day.
Travelodge Heathrow Central is only £21 for that day. It's actually in Cranford and not the immediate Heathrow area, but is only a £1.50 bus ride away (Oyster/Contactless fare).
robbeech
11 Nov 2015
Agree, at that time of year weather wise, with a long haul flight arriving well into the evening think you'd be pushing the 2035 if everything went perfectly, I would definitely second a cheap hotel in the nearby area and an advance the next day after the peak which will lower costs
Rob
