Island Platforms
Purple Orange
26 Dec 2019
The North
Are there any regulations that state how wide an island platform must be? I got thinking about how more platform(s) could be built at Manchester Victoria without disrupting the confines of the Arena, the arena car park and the tram lines.
  • Could an additional bay platform be built in the vacinity of P1&2? There seems to be under utilised space.
  • Could 4 bay platforms be built at the western end of the station?
  • And the left-field idea, remodelling P3-P6 to become P3-P7! Impossible I know, but that lead me to wondering how wide a platform needs to be. Piccadilly station platforms feel much narrower than the P4&5 island a Victoria.
6Gman
1 May 2012
There will be industry standards. But existing platforms will have "grandfather rights" to continue as they are.
I believe this document will be illuminating.
Peter C
13 Oct 2018
GWR land
Clapham north
That is a very thin island platform, yes. Although I wonder if, seeing as it's on London Underground's Northern Line and not the national network, it might be subject to different regulations, given that LU is its own system? Just a thought - happy to be proven wrong.
-Peter
Ianno87
3 May 2015
Clapham north
-Peter
Clapham North is teetering on the bounds of being outright dangerous. All similar Northern line islands (e.g. Euston and Angel) have been removed over the years. Serious consideration has been given to fencing one side off and making the station uni-directional (but that's probably not much better)
Lucan
21 Feb 2018
Wales
It makes me feel nauseous to stand on it, and I'm not usually one to be susceptible to things like vertigo or giddiness. Goodness knows how people cope who are - perhaps they board somewhere else. There is no way they's be allowed to build like that today.
bluegoblin7
10 May 2011
JB
Clapham Common also retains its island platform. The reality is that outside of peak hours the stations are not hugely busy, making it hard to justify investment to replace them (requiring the boring of new tunnels).
Those same peak directional flows also make any ‘one way’ scheme a non-starter - and indeed I’ve never heard or seen reference to that suggestion before. Have you a source?
To short cut the bedtime reading: minimum 4metres, but there can not be any obstruction in that space. Of course, you then have to work out how to get passengers between that platform and the street. In practice therefore, it needs to be an absolute minimum of 2.5m + width of platform access + 2.5m, with modelling used to prove that the width of the platform access, and the platforms themselves, will enable a safe evacuation under any reasonable level of expected passenger numbers.
Penmorfa
16 Nov 2011
North Wales coast
Surely platform doors would solve the problem?
Horizon22
Jobs & Careers
8 Sep 2019
Norwood Junction P2*/3 isn't much fun.
*P2 isn't actually used
Horizon22
Jobs & Careers
8 Sep 2019
Not much actually stops at P3 now and not long till it should get sorted.
Indeed, although I have caught the rare P3 trains. Long overdue a rennovation so am glad its happening soon.
ABB125
23 Jul 2016
University of Birmingham
Does that mean that you could have a 4m wide island, if the stairs/lift were right at one end of the platform (and the platform doesn't become a "usable platform" until you've exited from the staircase). If this makes what I'm saying any clearer, a 4m wide staircase end on to the 4m wide platform. Sort of like Bromsgrove station, but with narrower platforms (the ones at BMV appear to be 7m wide using Google Maps).
Ianno87
3 May 2015
Still needs platforms to be a certain width (the door structures themselves, take up width), plus the platforms (off memory) have a bit of awkward curvature on them, which isn't ideal for edge doors.
In theory, yes, if the pedestrian modelling showed that the crowding on such a platform could be kept to acceptable levels, and there was nothing else on the platform, eg shelter, any cabinets, etc.
ABB125
23 Jul 2016
Thanks - so possible somewhere like the Scottish Highlands, but not much else!
Reading platform 1 and 2 is about 4m wide, with end access, but the rebuilt platform 5 and 6 is more like 6m wide, I expect the main difference being that the latter is presumably designed to handle arrival flows off a 10 car as opposed to 5 car train?
Although presumably you could put up a large canopy supported in the middle? Would that require the platform to be widened (say by 10cm if the canopy supports are 10cm in diameter)?
You need 2.5m clear of any obstruction, even a lamp post. So a canopy makes the island 5metres plus the width of the support.
ABB125
23 Jul 2016
Ok, thanks. That seems a bit silly for things like lampposts (although much more understandable fro things like benches), but if those are the rules then those are the rules.
hwl
5 Feb 2012
OK, Blackpool North solution: Don't let the buggers on the platform until the train is there!
At 31tph each way?!!!
It was normal to have to wait 3-4 trains before being able to board before the current situation.
