Is this split ticket OK?
Kristofferson
23 Nov 2012
Hi guys, just a quick piece of advice needed please.
I have an Anytime Day Return from Kings Langley (KGL) to Euston (EUS). Something has come up and I need to stay on the return train to Apsley (APS).
On a train that leaves EUS as a peak service and calls at both KGL and APS, can I use my EUS-KGL ticket for part of the journey and an Off-Peak KGL-APS for the last "leg"?
MikeWh
15 Jun 2010
Crayford
If the off-peak ticket is valid on that train between KGL and APS then yes you can.
Kristofferson
23 Nov 2012
The booking engine allows it to be purchased for that train, so it's therefore valid right?
Thanks for the quick answer, appreciate it :)
Simon11
7 Nov 2010
Assuming this is a Off-Peak Return you are buying, it has the following restrictions:
Restriction : B3
OUTWARD TRAVEL
By any train except those
timed to depart Mondays to
Fridays before 0900
RETURN TRAVEL
By any train
Therefore it appears it will be valid.
Tetchytyke
12 Sep 2013
Isle of Man
So long as your train calls at both Apsley and Kings Langley (in the peak that's only the 1712, 1805 and 1840) you're fine.
