Deepgreen
The 700s have an unused capability for far greater acceleration but it requires major traction supply improvements to use it. I suspect it will never see use.
The problem is that would only be really useful on stretches of the BML, and with the volume of other traffic on the line it would just mean that they close up on the train in front and run on yellows.The 700s have an unused capability for far greater acceleration but it requires major traction supply improvements to use it. I suspect it will never see use.
Actually OHLE is fixed in more positions than third rail, which only rests on the insulators and is only fixed at cable joints.Yes, third rail is terrible at acceleration - because it's fixed to the ground.
B-boom tish.
(Sorry - couldn't help myself).
Indeed - I believe it was intended for the core where rapid throughput would be more useful.The problem is that would only be really useful on stretches of the BML, and with the volume of other traffic on the line it would just mean that they close up on the train in front and run on yellows.
The 8cars go far better than a 12 as the current limit is per train so they get a bit more oomph.The 700s have an unused capability for far greater acceleration but it requires major traction supply improvements to use it. I suspect it will never see use.
So to summarise the impact of the limitations of 3rd rail in the south:Actually OHLE is fixed in more positions than third rail, which only rests on the insulators and is only fixed at cable joints.
And the energy saving reduces because the distance between trains and substations or other trains regenerating is that much less.TBH the place where I think replacing 3rd rail with OHEL makes the most sense on the UK network is what the Electric Spine proposed, Basingstoke - Southampton as combined with other elements a great deal more freight could be electrically hauled.
If I were going to go about replacing 3rd rail with OHEL I would probably start furthest away from London and work inwards as once you get closer to the capital you are more constrained by traffic and signal distances.
It's a terrible idea* due to something called the skin effect, which means that an AC current only flows near the surface of a conductor. At 50Hz the depth is a few millimetres, which not by coincidence is about the radius of a 25kV conductor. If AC was fed through a third rail then the bulk of the cross-section wouldn't be conducting any current, so the resistance and the losses would be much worse than on the equivalent DC system.I know in some tram systems and other countries there are trains that use DC OHLE. But has there ever been AC third-rail systems? Would there be any benefit over a DC system (especially in terms of acceleration) , or is it a terrible idea?
There are many more lines that have been uprated to high current railway standards. The whole of the Brighton Main Line, both old boat train routes to Folkestone and SW to Southampton. Other routes have had localised reinforcement to allow longer trains/higher frequency. Its fair to say icing is top contact Achilles heel but incidents are infrequent and its certainly more resilient than OLE to mechanical damage. SW has the power supply now but no interest from management to get the units remapped as happened with the electrostars.So to summarise the impact of the limitations of 3rd rail in the south:
within the metro area, (up from Wimbledon, East Croydon, Orpington/Sevenoaks and Dartford), services run much as they would under OLE, most of the 3rd rail issues have been dealt with by massive investment in a massive number of feeds, - in some cases at a per block leveloutside that on the main lines, apart from the route of the ex-CTRL supply reinforcement, 3rd rail really does impact on the allowed performance of a capable and relatively modern group of fleets. Probably the biggest loss is the SW mainline, where with a good alignment, 100mph (or even 110mph in places) should be attainable by all EMUs west of Wimbledon to Eastleigh, irrespective of their length.The above is in addition to the overall shortfalls of 3rd rail, i.e. a lacklustre performance in icy weather, some safety compromises and a relatively poor power supply efficiency.
The Dutch railways uses 1500V DC. The 1970s sprinters accelerated from 0-70 mph in 40 seconds flat, as did the class 1700 locos on the short double decker sets. The reason I mention 0-70 rather than 0-60 is because I got distracted the first few times and when I glanced back at the speedo it was already well past 60! This was not a one off performance. It happened daily hundreds of times.I know in some tram systems and other countries there are trains that use DC OHLE.
Ah I see, I figured there was probably some reason why. Thanks!It's a terrible idea* due to something called the skin effect, which means that an AC current only flows near the surface of a conductor. At 50Hz the depth is a few millimetres, which not by coincidence is about the radius of a 25kV conductor. If AC was fed through a third rail then the bulk of the cross-section wouldn't be conducting any current, so the resistance and the losses would be much worse than on the equivalent DC system.
*but no doubt someone somewhere has done it.
The Dutch are very much considering upgrading their system to 3kv DC as per France and Belgium. Dutch trains are reasonable accelerators but have quite low top speeds compared to similar units in other countries. This isn't so much of an issue where distances are comparatively short though.The Dutch railways uses 1500V DC. The 1970s sprinters accelerated from 0-70 mph in 40 seconds flat, as did the class 1700 locos on the short double decker sets. The reason I mention 0-70 rather than 0-60 is because I got distracted the first few times and when I glanced back at the speedo it was already well past 60! This was not a one off performance. It happened daily hundreds of times.
EDIT: see video below. Fast forward to 9:40 where the train departs flat out from Amsterdam Sloterdijk. For context, these units were built the same time as the 313s.
Slight point of pedantry - 100mph on the SWML doesn't start until Byfleet. There's a previous thread with the mileages, but 110mph running on all existing 100mph section gains you very little time. The advantages of conversion would be efficiency and safety.Probably the biggest loss is the SW mainline, where with a good alignment, 100mph (or even 110mph in places) should be attainable by all EMUs west of Wimbledon to Eastleigh, irrespective of their length.
My understanding was that there was a long-term aim but no serious programme to convert to 3KV.The Dutch are very much considering upgrading their system to 3kv DC as per France and Belgium. Dutch trains are reasonable accelerators but have quite low top speeds compared to similar units in other countries. This isn't so much of an issue where distances are comparatively short though.
As a child in the 1980s I was always fascinated by the modern looking yellow trains over there. Even the 1964 units took off like a rocket but the SGM Sprinters were off the scale compared with anything else I encountered.The Dutch are very much considering upgrading their system to 3kv DC as per France and Belgium. Dutch trains are reasonable accelerators but have quite low top speeds compared to similar units in other countries. This isn't so much of an issue where distances are comparatively short though.
Only in the south, and for the high speed lines. The new wires around Mol are 3kV.Neighbouring Belgium uses 3kV but has adopted 25kV for recent work.
Slightly better on the stoppers' or intermediates' acceleration helping the paths issue, and a lot better on freight.Slight point of pedantry - 100mph on the SWML doesn't start until Byfleet. There's a previous thread with the mileages, but 110mph running on all existing 100mph section gains you very little time. The advantages of conversion would be efficiency and safety.
If freight can use the wires, which isn't many flow routes at the moment and even fewer terminals. Class 93 and 99 could change that though.Slightly better on the stoppers' or intermediates' acceleration helping the paths issue, and a lot better on freight.
It's only adopted 25KV where the line already has an end-on connection toNeighbouring Belgium uses 3kV but has adopted 25kV for recent work.
Or Luxembourg.It's only adopted 25KV where the line already has an end-on connection to French 25KV AC lines.
Actually only Luxembourg, apart from LGV NordIt's only adopted 25KV where the line already has an end-on connection to French 25KV AC lines.
Good point, correction noted! (They do have a connection to a french 25kv ligne classique at the BE/Lux/FR tripoint, but Brussels-Luxembourg is the corridor they're converting slowly).Actually only Luxembourg, apart from LGV Nord
I think I can see a 25kV route into France near Longwy that misses Luxembourg by a few hundred metres - boundary captions seem to have gone a bit haywire on openrailwaymap but I've cross-checked with Google.Actually only Luxembourg, apart from LGV Nord
How does a DEMU such as a Voyager/Meridian compare with acceleration? I’ve always found them quite rapid.
Fair enough, that will teach me for not zooming in enough! I would be surprised if much traffic uses that link thoughI think I can see a 25kV route into France near Longwy that misses Luxembourg by a few hundred metres - boundary captions seem to have gone a bit haywire on openrailwaymap but I've cross-checked with Google.
No 3kV in France as far as I'm aware.The Dutch are very much considering upgrading their system to 3kv DC as per France and Belgium. Dutch trains are reasonable accelerators but have quite low top speeds compared to similar units in other countries. This isn't so much of an issue where distances are comparatively short though.
You are correct, my mistake.No 3kV in France as far as I'm aware.
Don't think and 1.5kV has been converted to 25kV either. There are many places, though, where additional electrification has been at 25kV tagged onto existing 1.5kV network.
The Dutch looked at it several decades ago, AIUI, but decoded conversion to 3KV was better value given the Belgian network to the south and the fact the Germans are on 15KV 16.67hz.Don't think and 1.5kV has been converted to 25kV either. There are many places, though, where additional electrification has been at 25kV tagged onto existing 1.5kV network.
