Giugiaro
The Tube Map is, for sure, one of the most iconic art pieces of London. It's one of the first things visitors get in their hands to travel around and its style shaped the Underground's corporate image.
But the schematic style of Harry Beck's map, centred on the Central Line, is starting to get cramped, confusing and misleading. All because the Tube has grown too much for the original design to cope with.
Certainly that there are options that can be used to reduce the issues with the extensive network the Tube has, but there is NO WAY the iconic map would be swapped for anything else.
Although Geographic or Geographic based schematic maps are better to get a better understanding of the network and what are the fastest and shorter links available, the sheer size of some lines compared to Central London network makes such map impractical and inefficient in terms of space occupation. To make such thing practical, if so can be called, several maps had to be put side-by-side to zoom out from Zone 1 and 2.
For instance, the Metropolitan line in the Tube Map seems like a normal, outer metro line. But in a geographic perspective, the line should be renamed Urban Line. And Central isn't that far off as well.
And if we put the Overground, DLR, Tram Link and CrossLink together in the same map... well, things become really serious. Mainly because some connections like Watford (Met) and Watford Junction (LO) seen to be "purposely" set far away from each other on the Tube Map for the sake of the fares and still get away with it, but in a geo-map, TfL will have some explanations to do. :roll:
So, do you think that there's a urgent need of an alternative map to be used?
To which extent can or could Harry Beck's style be taken?
Does a different map mean the "death" of the Tube's spirit?
How important is it for the traditional Tube Map to still hang around as the official map?
What could be consequences of a map change, including money investment, habituation and overall corporate image of TfL?
