Is it possible to get from Birmingham to Bristol and avoid any tunnels?
tunnels
3 Dec 2022
Telford
Hi All
Not sure this is actually possible.
Thought I'd at least ask the question.
I know there's a big one on the route I took and got off the train and got a taxi to the next stop.
Looks like there's a coach, which might be a better option.
Thanks
35B
19 Dec 2011
Hi All
Thanks
In a word, no. If you are travelling from New Street, all exits are through a tunnel. If travelling from Snow Hill, the only route towards Bristol (via Stourbridge) goes through at least one tunnel (at Old Hill). Going the other way, you would have to travel from Moor Street due to the tunnel between Snow Hill and Moor Street, and there is no through route towards Bristol from there. If you then travelled towards Oxford and Didcot, you would encounter a tunnel between Leamington and Banbury, while there are then tunnels on both routes between Swindon and Bristol.
quantinghome
1 Jun 2013
Also there's no route out of Bristol that doesn't involve a tunnel. Even if you head south-west to Taunton or Exeter and then head back east.
ijmad
7 Jan 2016
I think the only line out of Bristol that doesn't pass through a tunnel is the GWML towards Plymouth/Penzance.
If you took that, you could change at Exeter, but the only alternative route back up to the rest of the country is the Honiton route which also has tunnels.
So I think no.
So I think no.
You can't get from Bristol to Exeter without going through a tunnel. Whiteball Tunnel south of Taunton.
ijmad
7 Jan 2016
You can't get from Bristol to Exeter without going through a tunnel. Whitehall Tunnel south of Taunton.
Forgot that one. So it's literally tunnels in all directions.
Tunnelphobes might have to take a bus.
Western Sunset
23 Dec 2014
Wimborne, Dorset
Afraid not. Whichever way one approaches Bristol, one encounters a tunnel:
Flax Bourton (between Bristol and Weston)
Twerton (between Bristol and Bath)
Severn (between Bristol and Newport)
Sodbury (between Bristol and Swindon via Badminton)
Wickwar (between Bristol and Gloucester)
Western Sunset
23 Dec 2014
Wimborne, Dorset
Plus the various tunnels between Patchway and Pilning, and various others around Bath (including Box). I only mentioned one for each route...
Grecian 1998
27 Oct 2019
Bristol
You could get from Birmingham to Bath via a massively convoluted route featuring only short tunnels:
Birmingham Moor Street to Banbury on Chiltern
Banbury to Oxford on XC
Oxford to Didcot on GWR
Didcot to Chippenham on GWR
Chippenham to Trowbridge on GWR
Trowbridge to Bath on GWR
The only tunnels on these routes are all 150m or less (Harbury, Bradford-on-Avon, and the two tunnels just east of Bath Spa) and it would take under 10 seconds to go through each of them.
There's multiple tunnels between Bath and Bristol, one of which is approx. 1km long), but from Bath you could get the regular X39 bus into Bristol, although this takes an hour rather than 12 minutes on the train.
This would realistically take far longer than a coach and you wouldn't be able to buy direct tickets as no-one would ever normally travel this way - you'd have to split up the journey. But it's an option if you have plenty of time, a general aversion to coaches, and can cope with very short tunnels.
RT4038
22 Feb 2014
So I think no.
Why would you not change at Taunton? I think you could go Bristol-Taunton-Reading-Oxford-Banbury without tunnels, but then you are stuck.
In summary the coach will be the better option for the OP.
Cambus731
19 Jul 2013
Chelmsford
On the subject of tunnels, I am quite claustrophobic, so I never use the deep level tubes. But I have managed to use the Elizabeth Line a few times, as I reasoned that it uses modern state of the art tunnels with a walkway and means of evacuation should the need arise. In the handful of times that I’ve been on the EL it hasn’t stopped in a tunnel between stations. Despite what I said I am concerned that if one were to stop in a tunnel, I’d have a panic attack and probably within about 30 seconds. Is it rare for EL trains to stop in tunnels? Or have I been very lucky in this respect so far?
Related to this, I do use HS1 quite a lot between Stratford and Ebbsfleet. I believe there are no stop signals in the lengthy tunnel between Stratford and Dagenham?
