gray1404
Is Brighton to Reading possible using a ENCT Pass and back a couple of days later?
Yes, unfortunately you are about 35 years too late for the erstwhile X62 coach that ran in the early 1980s between Reading and Brighton.Thanks so much guys. Its a shame this takes so long but its good that its still possible. I'll try and work out some times for the return leg too back to Brighton.
[Picture shows a screenshot of a leaflet for an Alder Valley X62 coach service from Reading to Brighton and Eastbourne which ran via Bracknell, Camberley, Aldershot, Guildford and Cranleigh, ie the route under discussion on local bus services now, around 1985]
Alder Valley gives you so much moreYes, unfortunately you are about 35 years too late for the erstwhile X62 coach that ran in the early 1980s between Reading and Brighton.
