Inverness to Haywards Heath - advice needed
Saperstein
28 May 2019
Chester
Hi,
Im travelling from Inverness to Haywards Heath on Monday 23rd and would like to arrive at a reasonable hour, say by 2100 so will probably have to leave Inverness quite early.
I would like step-free changes if possible! I can manage escalators but struggle up and down normal stairs.
I hold a Disabled rail card. Is splitting best and is it generally quicker on ECML or WCML?
Would like to avoid the tube if at all possible, last time I came out of the wrong exit at Victoria tube and missed it advance Southern service. Fortunately for me, the train has been cancelled anyway.
The best fare I have come up with so far is £118.59 INV-GLQ GLC-EUS VIC-HHE. (splitting at Glen eagles, Glasgow, Oxonholme Lake District, East or West Croydon and Gatwick Airport.)
Thanks for any advice.
Saperstein.
Shotton
10 Jun 2019
A cursory look at trainsplit gives an advance on the Highland Chieftain @ £62.70 with a disabled railcard, with a single change at King's Cross.
07:55 Inverness - 15:49 Kings Cross
walk to St Pancras,
16:20 St Pancras - 17:22 Haywards Heath.
I think this would probably be the best option; I doubt a slower itinerary would save much, if any.
(note, I can also get the same price leaving 07:55 Inverness and changing at York and Stevenage, to arrive in Haywards Heath for 17:29 if you wished to avoid London. However, this requires two fairly quick connections)
30907
The advantage of going through to KGX is that you have a better choice of train at STP going towwrds HHE in case of delays/cancellations.
How crucial is it that you arrive on time?
If potentially being delayed is no issue, but keeping to cross-platform interchanges is important, then go for the option to change at York & Stevenage.
If you want to minimise the chance of a delay and have an overall quicker journey, then change at King's Cross/St Pancras. No steps at KGX, and there are lifts available (or escalators) at STP.
Saperstein
28 May 2019
Chester
Thanks for all the advice.
I need to be at HHE by 21:00 at the latest really, looking at the advance changing at KGX and STP it looks like the advance part of the ticket only applies to the Highland Cheiftain?
It says:
“Specified train only. No refunds.
Only valid on booked London North Eastern Railway services and required connecting services.”
Does that mean I don’t have to rush between KGX and STP? If so that’s ideal.
Saperstein.
AlexNL
19 Dec 2014
Kings Cross and St. Pancras International are right next to each other, they even share a tube station. 30 minutes should be ample time to get off an LNER service at KGX and change for a Thameslink train at STP. :)
Thameslink don't have Advance tickets, nor seat reservations, so if you'd miss the 1620 from STP you could get a later train. During peak times, there are 5 trains an hour from STP to Haywards Heath so the wait won't be long.
mmh
13 Aug 2016
Well we arrived over an hour late into KGX so I guess that’s 50% or the single or is it 100%?
https://www.realtimetrains.co.uk/train/Y75715/2019/09/23/advanced
Still got to HHE in good time (for me - not in the itinerary! ).
But does that matter? as the VTEC train was delayed.
Saperstein.
I'd have thought it would depend on the delay for the whole journey to Haywards Heath, comparing the scheduled time had you been on time at King's Cross and took the next train from St Pancras to Haywards Heath respecting the minimum connection time, to the actual arrival time had you taken the next train you could following the delayed train.
That is, the delay is calculated on the end to end journey, not constituent parts of it. I am very open to correction on this, however!
Saperstein.
As your journey was to Haywards Heath, it is the arrival time into HHE that matters.
As you've not (yet) divulged your original contracted arrival time or the actual arrival time, we are not currently able to say what compensation you are due.
hkstudent
11 Nov 2018
SE London
For journey delayed 30-59 minutes: 50% of single fare
For journey delayed 60-119 minutes: 100% of single fare
For journey delayed 120+ minutes: 100% of return fare
As said, we need your actual and contracted arrival time of each leg of the journey (Inverness - KGX ; STP - Haywards Heath) to provide you with the tailored advice.
I guess the OP has taken this journey:
https://www.realtimetrains.co.uk/train/W76487/2019/09/23/advanced
Which is 60 minutes later than the NR Journey Planner suggested journey
I think if holding more than one tickets, it is possible to claim constituent parts of it if the payout value is higher (e.g. getting to the destination on time as you run to catch the connection)
Saperstein
28 May 2019
Chester
Thanks was due into KGX 1547 But arrived 1652.
Was due into HHE at 1722 but arrived 1824.
One single through ticket.
Saperstein.
hkstudent
11 Nov 2018
SE London
Saperstein.
That's easy, claim the whole journey for 62 minutes delay, which would give you 100% of the single fare from Inverness to Haywards Heath.
Wallsendmag
11 Dec 2014
AlexNL
19 Dec 2014
Not bad really, if you weren't in a rush in the first place :)
I do wonder what caused the late running. The train gradually seemed to lose time as the journey progressed.
paul1609
28 Jan 2006
K
In my experience that's very common for ECML trains from Scotland to London especially the north of Edinburgh ones. Edinburgh to london will very often be 5 hours plus rather than the headline times.
