Invalid bank cards permitting exits at TfL barriers
assimilated
3 Aug 2024
I was watching this show (the video should start at the relevant part at 2m 30s) and it appears to indicate that an invalid bank card will permit a passenger to exit through TfL barriers. There's another episode where this is even true of a lost or stolen bank card which has been blocked by the bank.
Can anyone explain why this would be the case? Surely a card which has been blocked or declined by the bank should be rejected by the barriers?
Mike395
23 May 2009
Bedford
Short answer - speed. Ticket gates don’t wait for an online authorisation response from the issuer as it’d mean a few-second delay in the gates releasing; not practical on a mass transit system. Relying on an internal blacklist within TfLs network is much faster but it has to know the card exists in the first place.
Fawkes Cat
8 May 2017
And this also means safety. If each card was checked on exit (with, as above, a few seconds delay) it's not hard to imagine the whole barrier line being blocked, with extra people coming up the escalator from behind. That's how crushes happen, and if TfL have decided safety trumps revenue protection then I agree with them.
Mike395
23 May 2009
Bedford
Indeed - it's also the reason why even if a card is declined when TfL runs the background preauthorisation (usually within a few minutes of the first touch-in on any given day) you will be allowed (once) out of the system with the same card.
3rd rail land
30 Jan 2019
Where the 3rd rail powers the trains
Does a declined card go on to TFL's internal blacklist after a few uses? Does the gateline check the internal blacklist each time a contactless card is tapped? I assume the answer to at least one of those is no for such prolonged use of a declined card to happen.
I was surprised that this was broadcast
Perhaps the thinking was it will deter others from doing this if they know TFL will eventually catch up with them.
assimilated
3 Aug 2024
The other aspect that was unclear to me is why they have to use an exit gate to enter. If the system isn't doing a real-time check, then surely they could use a normal entry gate?
Haywain
3 Feb 2013
Once the card is blocked it won’t open an entry gate, but it will always open an exit gate.
assimilated
3 Aug 2024
Ah, so it's not doing a real-time authorisation, but it is doing a real-time check of a database of blocked cards? And that check would take too long at the exit barriers?
Haywain
3 Feb 2013
No, the system is designed not to prevent exit. Similarly, with an Oyster card if you have been allowed to enter the system you will never be prevented from leaving.
assimilated
3 Aug 2024
If I understand correctly, National Rail barriers do block exit, so this difference simply reflects the greater crowding in tube stations?
blimmo
30 Jul 2025
West Mids
I believe TfL changed the behaviour of blocked cards on exit to reduce the confrontation that gate line staff had to deal with.
I suspect national rail barriers are operating on the assumption that the entry station is likely to be unbarriered whereas TfL are operating on the assumption that both entry and exit are barriers.
Trainman40083
29 Jan 2024
Derby
Well, thanks for giving a thorough answer. It certainly had me wondering, after watching that programme.
mmh
13 Aug 2016
I think that's unlikely. Pay as you go Oyster has always allowed cards to always exit (a negative balance can exit) and I imagine when it was expanded to contactless it similarly allowed all cards to exit.
davews
24 Apr 2021
Bracknell
I was puzzled when I watched that programme. I take it he was entering the station through the exit barriers which would have been displaying a big red cross. So he has to stretch over to tap his card at the other side or is the reader on the outer side still active? Presumably if he tried to put a paper ticket in the slot at that side it would be blocked? Or maybe we shouldn't be probing too much the details...
assimilated
3 Aug 2024
If my understanding of all of this is correct, I can see a major flaw in the system. I probably shouldn't post the details here, but I think I see a way the flaw could be exploited to allow a fare evader to tap in as well as tap out, and which would be completely undetectable by the data trawl system. If anyone here works for TfL's fraud team, please PM me.
Haywain
3 Feb 2013
Some time ago we had a case on the forum of someone who had done exactly that, and then got caught.
TfL clearly register the details of cards being used to "escape" the system in that way, and set up operations to catch prolific offenders. It may not be a perfect process but it is certainly detectable.
Mattplans
27 Sep 2024
London, UK
If we can think back to when Revolut and Monzo banks became popular, it was apparently easy to open accounts with them, there was a ‘hack’ floating around on Tiktok etc that even with £0 on your account, you can always touch out.
This is when it went 'viral' that you can reach over to allow entry and just do the same at your destination. I recall watching tiktoks labelling this as a "TFL hack" or "free travel hack" etc a couple years back.
I have no personal knowledge of how difficult it is to open an account with any of these banks, but I imagine the sudden attraction is that it was easier to do so under pseudonyms or false details so you can be anonymous? Since they have no IRL branches and all verification takes place online.
I believe some retailers/merchants now have a blanket ban on these banks because of these “vulnerabilities”. I have heard enough stories of individuals having difficulties with these 'branchless' banks to put me off ever wanting to open an account with any of them!
It’s the Nov 23 thread linked in post #19 by @dosxuk - I’ve just had a read because I was pretty sure this has been a well known ‘feature’ since a particular software upgrade, and in fact it’s all quoted in that thread.
Adam Williams
2 Jan 2018
Warks
I don't think this is accurate; Monzo for example still do KYC checks as you'd expect any regulated bank to do. You need to provide ID and record a video selfie. They have done this since day 1. Digital verification doesn't mean worse verification, and arguably there's far more data they can use to help make a decision than if you did it at a legacy bank by filling in paper forms.
bubieyehyeh
25 Feb 2016
I've noticed where the person in front of me enters using a mobile phone on yellow pad, the gate opens but then the led on the yellow pad flashes red. Not sure if its another hack, it was very common to see this, less so in last few months.
Haywain
3 Feb 2013
I have noticed something like that happening when scanning eTickets.
Railguy1
6 Apr 2016
See above for example. Negative credit can open thr barriers and that has always been the case.
I really don’t understand your comment on vulnerabilities either. Do you have any evidence for this?
Starmill
18 May 2012
Bolton
This isn't what's happening. You can't be blocked into the system because TfL made a deliberate choice that this was the best option.
The system may not even have received the entry tap when you exit. This is the same for Underground and other stations. The same hardware and database are used at all of them.
There are rather a large number of ways to get inside the ticket gates without having touched in. Get on any train at Hanwell or Mill Hill East, nearly any DLR station and a large number of national rail stations and you can immediately access the paid side areas. There are also lots of agency staff who will just open the gate rather than arguing if they're shown an expired ticket or one that has been picked up off the floor, or stations where not every entrance has the gates closed at the same time. People also jump remotely-monitored gates all the time and nobody sees them do it. It's really not unusual unfortunately.
island
30 Dec 2010
This isn't correct. Oyster cards can be invalid for exit even if cleared to enter, for example if they were hotlisted but had dropped off the locally stored list because of non-use. In the past, exit was also denied for lack of OEP when needed.
Other options I'm aware of being used are "visa gift cards" purchased at retail, multi-store prepaid cards issued from Westfield and the like, as well as French luncheon voucher cards.
I know from a very good source that one newer bank came very close to having all their cards banned from TfL because of the level of problems with their customers.
