Interrail Passes
smid
16 Sep 2013
it's a letter I not a numeral.
I did say 'I' the letter in that post.
And yeah, none of this is matching up with the interrail.eu website, the number on the back doesn't have an I in front of it, and there's no QR code. Starting to think I'd be laughed when trying to use this ticket in real life...
As above, I've got a 4 day pass for July, and I have a question for the megaminds here, if they know.
We love Antwerp, Belgium, and are doing a one day over back in the middle of July, so using our in and out of the country days first, leaving 2 days after.
Then we're flying to Germany a few weeks later, and plan to use the other 2 days to go from Frankfurt to Berlin 1st class. We can still do this, right? The in and out of the country days don't end the validity of the remaining days, right? I hope so, and I assume so, but I'm am having a wibble in case it isn't so and I find this out from a german rail conductor who I can't argue with.
As I understand it, your pass is valid for a month from its first use, so your Germany trip a "few weeks later" needs to be within the month of validity.
smid
16 Sep 2013
Realised one of the numbers I have has an E in front of it, tried that, nope. Tried the interrail.eu chatbot and none of the numbers I have worked, nothing on the tickets, order id. I found the login for myinterrail.co.uk hidden away via google (not on their front page weirdly), and it only really had my order details, I think the site claims to be nationalrail.co.uk.
I've got support requests in with myinterail.co.uk (which might be Mon-Fri 9-5), and interrail.eu. I will report back on this weird abberation of usage. I suspect the number I have on the back preceded with an E is the number I want, but isn't working.
I think I've got it. Terminology and assumptions.
I've had a printed ticket, within a glossy ticket cover envelope it is stapled to. The type of ticket typically issued 20 years ago. The glossy cover, which I assumed was just like that (like it would be with a plane ticket). The numbers are printed on the glossy cover, not the ticket itself.
scragend
27 Feb 2016
Worth pointing out that the pass number that you enter when you book a Eurostar reservation doesn't actually appear on the Eurostar ticket anywhere. There's no connection so as long as you could produce a valid Interrail pass along with your Eurostar passholder ticket if asked (I never have been), to prove your entitlement to the passholder fare, then that would be fine.
I just did a dummy booking on Rail Europe using the pass number (6 digit, alphanumeric) for a mobile pass I've bought which I intend to use in July. Validated.
I tried the same booking but using the number from a pass that expired last month. Not valid.
However... I used the Pass Cover Number generator on the Interrail/Eurail web site to generate a Pass Cover Number from the number of the expired pass. I put this Pass Cover Number into Rail Europe. Validated.
I then used the same generator with a completely fictitious pass number to generate a Pass Cover Number and put this into Rail Europe. Validated!
I then just entered AAAAAA into the generator and used the Pass Cover Number that it gave me on Rail Europe. Validated!
So it appears that Rail Europe can identify an expired/invalid pass number, but not so much with a Pass Cover Number. Either way, once you've managed to buy the passholder fare, Eurostar aren't going to care what number you used to buy it.
Andover
30 Mar 2019
Are you sure you have an Interrail pass, rather than an Eurail one? Assuming you're a UK resident, that would be a serious problem.
rvdborgt
24 Feb 2022
Leuven
Correct, since there's no way of doing the latter. The only thing they can do is match the given paper pass cover number with the known series that have been released. But there's no way of knowing whether a certain PCN has already been used, and if so, on which pass with which validity.
smid
16 Sep 2013
Yes, it's sorted now. The number was on the back of the glossy ticket holder, the number on the paper ticket itself wasn't the one.
rvdborgt
24 Feb 2022
Leuven
It's not without reason that it's called the pass *cover* number :)
scragend
27 Feb 2016
Makes sense, thanks.
Essexman
15 Mar 2011
Can anyone tell me how to cancel a Eurostar booking (more than 7 days in advance) made with Interrail pass?
I can't find how to do this on either the Eurostar or Interrail websites?
Thanks
JB_B
27 Dec 2013
Thanks
I'm guessing that you've got a six character Eurostar booking reference? When I've needed to cancel an Interrail reservation in the past it was an option under "manage your booking" at https://www.eurostar.com/uk-en ( I don't have current booking to check if that still works. )
mad_rich
12 Feb 2013
Newcastle
Thanks
Interrail reservations for Eurostar aren't refundable AFAIK. You can change the time and date (but not route) on the Eurostar website, at a cost of €15 or €20 IIRC.
scragend
27 Feb 2016
That was the case but, since the changes at the beginning of last month, the Interrail web site is now saying (my bold):
  • Eurostar Continental and Eurostar London (purchased on or after 6 May 2025)
    • Refund conditions:
      • Up to 7 days before departure, refundable with a fee (£10/€15 for Eurostar Standard and £15/€20 for Eurostar Plus).
      • Less than 7 days before departure, non-refundable.
    • Exchange conditions:
      • Up to 7 days before departure, exchangeable without a fee.
      • 6 to 0 days before departure, exchangeable with a fee (£10/€15 for Eurostar Standard and £15/€20 for Eurostar Plus).
      • Reservations exchanged between 6 and 0 days before departure are non-refundable.
    • All refund and exchange requests must be submitted via the Eurostar website, including payment of any refund/exchange fees.
https://www.interrail.eu/en/interra...change-and-refund-conditions-for-reservations
@Essexman When did you purchase the reservation?
Essexman
15 Mar 2011
Yes I've got the booking reference but it isn't an option in Manage my Bookings. Only to change the date.
Purchased it in January so that would explain it.
Ringo2112
9 Jul 2021
United States
If I have a Eurail pass issued on Dec 13 and must be activated by Nov 13 2025, does that mean I could start my 30 day pass on Nov 12? It doesn't have to end by November 13, correct?
Yes, the 'latest activation' date doesn't mean the pass expires by then. It's simply the last day on which you must activate it.
rvdborgt
24 Feb 2022
Leuven
The latest possible start date is then 13/11, and the last day of the validity period would then be 12/12 (30 days indeed in this case).
DesDobramento
12 Jun 2025
Portugal/UK
My Interrail agent has suggested that Eurostar Passholder fares only apply to Global Interrail passholders, ie not to those with a One Country Interrail.
signed
13 May 2024
ROI
They are also valid with the One Country Benelux Pass between Brussels and Amsterdam
  • The One Country Benelux Pass is also valid for selected Eurostar (continental) trains between Brussels and Amsterdam, provided you have an additional mandatory reservation. Residents of Belgium, the Netherlands or Luxembourg cannot use the Pass in their country of residence while using the Benelux Pass. Both countries need to be included in the Pass when travelling by Eurostar.
notverydeep
9 Feb 2014
Does anyone know when bookings for Interrail reservations will start for the timetable commencing on 14 December 2025? I'm particularly keen on a few specific Eurostar and sleeper options in the run up to Christmas that are already open for normal bookings and might be busy at this point.
Eurostar can be booked a long time ahead, possibly as far as they sell 'public' tickets. You can do so on the Interrail website if you already have a pass, or otherwise through RailEurope or HappyRail. RailEurope is the only fee-free option but their passholder site doesn't work on mobile for me at the moment. I got it to work on desktop by pressing F5 (note: not Refresh!) after it fails to load the first time.
Eurostar passholder availability is tied to whether the public price exceeds a certain threshold - something around £140 o/w in Standard and £170 o/w in "Plus" (former Standard Premier) for the Brussels route - I haven't checked the other routes.
rvdborgt
24 Feb 2022
Leuven
If you're looking on the Interrail website: that's the last place to look for either timetables or reservations.
In general, use this page as a guide to pass reservations:
For Eurostar, raileurope.com is recommended, since it indeed does not have any added fees. Do change the currency to euro to avoid their 5% mark-up for other currencies.
notverydeep
9 Feb 2014
Thanks for this. I was indeed looking at the InterRail reservation site - there was I thinking that the site intended for the purpose would be the best place to go! Silly me, I've been in the rail industry long enough to know that is rarely the case... I should have known it would be better to go to straight to seat61! However, even using the recommended options there, neither the OBB or MAV websites are offering any sleeper trains to Romania for reservation after the December timetable change.
I'm intending to use either of the Dacia (from Vienna) or Ister (from Budapest) to Bucharest. The OBB site does list the new timetable times for Dacia, but it can only be booked before the timetable change. The MAV can book Ister up to the timetable change, but has no trains to Bucharest subsequently. I guess I will have to wait and keep trying for those.
Thanks also @Watershed, the raileurope.com site does indeed have the Eurostar train I want to book available, despite it not being available through the InterRail reservation site.
rvdborgt
24 Feb 2022
Leuven
That just means reservations have not been opened yet. Not surprising, honestly. Just keep trying.
Going by past experience, it may be late November before they load the 2026 timetables.
peteb
30 Mar 2011
Just been alerted by SNCF to a revised Paris Berlin service from December going via Erfurt. Tried to reserve a seat for a random date mid-Jan and told bookings open 30 December .............
rvdborgt
24 Feb 2022
Leuven
If you tried that on the regular bahn.de booking page, then you're trying to book the wrong reservation and you'll have to pay for a new one on board, of course with an added on-board fee. DB don't make a lot of effort to make it clear that the regular €5.50/6.90 reservations are not valid with an Interrail pass for a journey from/to France on that train and just limited the online booking horizon to 2 weeks.
Please always check the pass reservation page on Seat61. There are a number of ways to book this €19 reservation and as you can see on the SNCF website, these trains can be booked until way past January.
peteb
30 Mar 2011
Useful advice, thanks!
It's a pain trying to get across the border from France using inter-rail. Even Strasbourg to Karlsruhe attracts their (in my opinion) inflated reservation fee. Whilst it is possible to bale at Strasbourg and continue by regional trains into Germany then resume the journey it makes it a pain when you've luggage. What's perhaps better is to buy an advance ticket from SNCF to the first stop in Germany (using a Railcard, eg senior) then resume using Inter-rail which is not restricted within Germany.
Yes, I checked that and it's about €22 single ICE Strasbourg to Karlsruhe a week in advance.
