Interchange Hacks: Circumventing Hostile Signage
tuberculosis
24 May 2026
Bit of a niche obsession, but I’m fascinated by London Underground interchange “hacks” that deliberately circumvent hostile signage designed for normies rather than optimal movement.
My favourites are probably:
- Victoria (Victoria ↔ District/Circle via either Lift K from the Victoria line, or via the eastbound District line platform from District/Circle — also useful if entering the station from street level for any line).
- King’s Cross St Pancras (follow the signs to the Circle line to change via the old ticket hall tunnel network rather than the newer routing)
Recently discovered a good one at Whitechapel too. When changing from the southbound Overground for the District line, follow the signs to the Elizabeth line off the platform initially, then route more directly to the District thereafter. This avoids the indirect crowd-management route.
What I’m now curious about is whether anyone has fully cracked post-redevelopment Tottenham Court Road. The rebuilt station feels like it was designed around passenger-flow management rather than shortest-path routing, and I strongly suspect several “wrong-signage” routes are materially faster depending on line, direction, and train positioning.
Has anyone mapped out the optimal protocols yet for:
- Central ↔ Northern
- Elizabeth ↔ Central
- Elizabeth ↔ Northern
eggcentric referred me to this forum as the sort of place where people might actually have opinions on this.
PS: I assume everyone here already knows the classic Green Park one: Piccadilly ↔ Victoria via the escalators up to the main ticket hall rather than the signed interchange tunnel. It's a simple station without too much of a payoff, but still a sturdy protocol to have in the playbook.
81A
22 May 2026
GWR land
Agreed re Tottenham Court Road, I always feel like I am going the “long way round” but have not worked out any short cuts yet… Another one is Paddington Bakerloo line, the signage for national rail points to the new Paddington Square exit while following the signs for the Circle/District lines leads to the ticket hall with steps/escalators directly into the national rail station. Admittedly the Paddington Square route is not much longer (or even faster when the passage to the Circle/District ticket hall is overcrowded) but it is useful to know if it is raining and you want to avoid going outside (even if only briefly).
Central
20 Oct 2017
Irthlinborough
Find the Victoria-District interchange at Victoria is a bit of a hike now,used to be straight up the escalator from the Victoria platforms.
bcarmicle
11 May 2018
For TCR, looking at maps, I believe there's an escalator between Central and Northern lines at the northern end of the Northern line platforms that leads to the southeastern end of the Central line platforms. I don't know what the signed route is so would recommend a little exploring if no one here has advice.
Elizabeth to Northern line - I think the signed route is fine; you just want to be on the eastern end of the Elizabeth line to avoid having to walk the whole platform.
Northern line to Elizabeth - go up the entry staircase (roughly middle of platform), and turn right, that should take you to the Elizabeth line concourse.
You may find TfL's axonometric diagram of TCR helpful: https://foi.tfl.gov.uk/FOI-1497-2425/Tottenham Court Road 1.pdf
Elizabeth - Northern line at Tottenham Court Road is very simple: be at the eastern/southern end of the train and stay at platform level, rather than going up any escalators. There's a lift or a couple of steps between the two.
There's an unsignposted corridor to/from the far eastern end of the westbound Elizabeth line platform, which allows a marginally quicker interchange. But going via the central passageway between the platforms doesn't take much longer.
tuberculosis
24 May 2026
Thanks all.
@bcarmicle, the axonometric map is extremely helpful. Looking at it, the station geometry suddenly makes a lot more sense. It really does seem like the Elizabeth line was effectively bolted onto the side of the old Central/Northern complex rather than integrated cleanly, which probably explains why the official routing often feels so implausible. I agree there are probably some diagonal platform-end transfers that beat the signed routes once one learns the layout properly.
@81A, I genuinely did not know the Paddington one. That is the sort of thing I mean: not necessarily massively faster, but clearly more correct on principe.
And @Central, yes, absolutely. I still mourn the pre-one-way-system Victoria interchange days.
@Watershed, that's excellent. That unsignposted far eastern Elizabeth corridor is exactly the sort of "in a nutshell" thing I was hoping people here would know.
From Victoria mainline station to the Victoria line I always cross the back of the bus station forecourt to enter via the staircase north of the eastbound District / Circle line platforms to avoid the circuitous tunnel route.
tuberculosis
24 May 2026
Yes, and straight to the Eastbound district line platform in all cases unless travelling westbound on the same.
Peter Mugridge
8 Apr 2010
Epsom
So many people ignored the no entry signs above the short cut from the northbound Northern Line ( Charing Cross branch ) at Euston that it's now got directional signs above it!* :lol:
*Except for the very last short section, immediately before the escalators, and the remaining no entry sign there is totally ignored anyway.
bcarmicle
11 May 2018
I’ve not used Euston in a while but I thought that the CX branch only had two exit to the rest of the station - the official entry on the SB platform and the official exit on the NB platform - what’s this shortcut?
Turtle
18 Mar 2013
It's not just the interchanges. A surprising number of passengers using Great Portland Street are, or were, unable to distinguish between the Exit and Entry stairs. I lost count of the numerous times I had to battle puzzled exiters out of the way as I descended the entry steps to the Eastbound platform.
Recessio
4 Aug 2019
Is that staircase the "Cardinal Place" new big glass entrance? Or a differentone? I haven't tried using the Cardinal Place entrance. When coming from mainline at the moment I keep left when entering the ticket hall, follow the signage to District/Circle, tap in and cross that narrow bridge corridor, and go to Victoria that way. It avoids the big winding corridor to the Victoria, at least, but I'd be interested to know if there's an even quicker way I haven't discovered!
I am describing this entrance, perhaps poorly, not going on further to Cardinal Place.
Peter Mugridge
8 Apr 2010
Epsom
Lol about GPS. Yes, also curious about this Euston shortcut.
Let's say you get off a northbound train... exit via the stairs right at the front of the train. Top of the stairs, don't follow the crowd ahead - turn right, then left down the second passageway. This is the one that used to be marked "NO ENTRY", but now only the final segment is. Keep going ahead, at the end you have a right turn onto the bank of three escalators that lead up to the main ticket hall.
It's about 30% quicker than just going straight ahead and then right with the rest of the crowd.
Egg Centric
6 Oct 2018
Land of the Prince Bishops
I feel honoured to be called out like this :lol:
While not quite what you asked in the OP, just to mention as per our initial discussion that in a similar vein if you want to get from the Elizabeth Line (or Thameslink but I'm not sure whether it's quicker to go via surface or not) to Barbican there's no need to change onto the sub surface lines - there's an exit from the Farringdon Lizzy Line platforms directly into Barbican station itself.
sh24
28 Sep 2023
TCR Central line in the pre Elizabeth Line days - as you came off the escalator bank there was a no entry on the right hand side that took you directly to the eastern end of the platforms. This avoided a walk down the corridor. Not sure if its still there?
The spiral staircase down to the Northern Line platforms is no longer in passenger use, sadly.
Dave W
27 Sep 2019
North London
I am a frequent user of Victoria and the Covid one way solution sticking is very annoying. I actually used Cardinal Place "in anger" relatively regularly, the exit was great but the long winding route to the escalators down to the Victoria was infuriating - why they can't do directional flow on the long escalators at the north(?) end of the Vic platforms is beyond me. At very busy times when the walk round to the Victoria Line was a trudge, if you timed it perfectly you could dive up to the westbound subsurface platform, then along and down to cut out the circuitous route. At your peril though, because if you hit a scrum for the District Line you definitely don't save time...
Best option though is the bus station entrance for the Eastbound Dist/Circ and hang a left! - the one next to Market Halls (and in the days of being lazy a quick hop from St James' Park for drinks there). Not so easy when I've got a pushchair these days - although the step free options at Victoria are immeasurably easier - infuriating when (able, mobile) people grasp this and clog up lifts for those of us who really need them, though!
PS. Although I moan about the developments and Covid rules around the Cardinal Place exit work, I can't actually remember what the station was like before - was the long winding tunnel not there and the escalators at the station end bi-directional?
sh24
28 Sep 2023
Yes, it was bi-directional escalators directly up from the Victoria line (and consequent congestion) and then the two narrow little tunnels from the sub surface lines serving the other escalator bank down to the Vic.
I don't love the new Victoria but at least it isn't overcrowded.
jumble
1 Jul 2011
It seems quicker and certainly a lot less walking at Green Park if changing from Piccadilly to Jubilee to go up to the ticket concourse and back down again.
Recessio
4 Aug 2019
Conversely, I've never managed to figure out the Thameslink/subsurface layout of Farringdon. It's four platforms next to each other, but I find I always end going what feels like a really long way around (or sometimes, staircases leading to locked gates or dead ends), no matter whether I strictly follow the signage or disregard it and head in what "feels" like the correct direction. I don't understand how four platforms next to each other has managed to feel so complicated!
AndrewP
5 Sep 2011
Is the best hack for the Victoria Line at Victoria if heading north especially (depending where you are in the area) actually walking to Pimlico as the trains are quieter and the station is quiet and straightforward unlike the maze that is Victoria?
Another hack is at Kings Cross, although not an interchange, head for the old south ticket hall when heading for the deep tubes as the underground walks are so much shorter and quicker than the signposted north ticked hall
Peter Mugridge
8 Apr 2010
Epsom
If northbound - back on the 4th ( 12 car train ) or 2nd ( 8 car train ) from the front puts you right next to the way up to the footbridge - 90 seconds to get up, across, and down to the westbound Circle platform. One minute longer to the eastbound.
If southbound, there's a set of stairs roughly mid platform which lead straight to the westbound Circle platform. Up and over the footbridge from the front of that platform to get to the eastbound one.
...and in reverse for the opposite direction. Off the eastbound Circle, back of the 4th carriage ( both S7 and S8 ) is close to the way up to the footbridge.
sh24
28 Sep 2023
It's a 12-20 minute to Pimlico depending on where you are, so I'd say not really. Trains are a bit quieter but the Northern at Stockwell dumps a lot of people and Brixton isn't exactly a wasteland.
tuberculosis
24 May 2026
The ticket hall change for anything involving the Jubilee line at Green Park is at best a tiny saving from experience and my understanding of the platform layout. It's a no-brainer for Picadilly to Victoria changes in either direction however.
Central
20 Oct 2017
Irthlinborough
Where the new route to District is used to be the station inspectors office,train maintainer’s room with staff toilets and PWay room round the back.
Timmyd
28 Jun 2014
Endorse the ones above and a few others:
- Bond Street, entrance to Jubilee. Ignore the second set of down escalators which takes you via a convoluted route below the platforms and back up. Instead turn left at the bottom of the first escalator and then use the original Jubilee escalators down to platform level, there is always one set running down to facilitate interchange
- Bank, the signage for the recent improvements leaves a lot to be desired. If exiting Northern Line, the Way Out signage takes you to Cannon Street, not close to 'Bank' at all, but the original bank of 4 lifts to Lombard Street ticket hall still operates, with barely any signage. Follow signs to Waterloo & City line from the Northbound platform. This route is also arguably a quicker interchange from Northbound Northern Line to Central now that it is deserted, as opposed to using the travelator/escalator combination
- Notting Hill Gate. Going Central to Circle/District the signs will make you take a second or third (depending on which platform you've come from) escalator to the booking hall. Instead, continue straight ahead, one of the paths is usually blocked by a Bostwick Gate but the other is always open and signed in the reverse direction only and the passage will take you direct to the platforms
- Holborn. Heading to Westbound Piccadilly Line, the signs send you to turn right towards the platforms but there is a gate to the left which is always open at the bottom of the second set of escalators. Cut through here and there is a wide staircase leading directly to the Westbound platform
AndrewP
5 Sep 2011
Totally depends on where you are though - if you are south of Victoria Street, e.g. near Horseferry Road, it can work well - just my personal experience
Recessio
4 Aug 2019
Thank you, tried that this morning coming off of a northbound Thameslink and it was great! The staircase didn't have much signage which might explain why I've missed it in the past
