Increased Northern Services between Newcastle and Middlesborough.
GrandCentral
8 Aug 2017
When Arriva secured the Northern franchise part of their plans included half hourly services down the Durham Coast Line between Newcastle and Middlesborough. These were due to begin in December 2018.
As far as I'm aware these are yet to begin and it's all gone a bit quiet.
Do we have any news on when/if these services will ever materialise or is Northern in too much chaos at the moment?
Anvil1984
28 Aug 2010
There’s never been any plans for half hourly services between Newcastle and Middlesbrough via Durham Coast just an additional service on the morning and a couple of later evening ones.
The second service was intended to be a Northern Connect service with a Start Date of December 2019 with the intentions of running it via Ferryhill / Stillington between Stockton and Durham
IIRC much of the discussion at the time of the franchise announcement was about how the “Connect” route wasn’t clearly shown on the service diagrams, and I still don't remember it being satisfactorily explained. Have I missed it being stated since then as definitely running via Ferryhill?
Anvil1984
28 Aug 2010
Managers at our place have said it’s most likely to be going that way. The writing next to the map stated it would be going via Durham which would discount the Coast route and it was in one of the franchise agreement documents they had to at least do a feasibility study of sending trains that direction
Thanks for the explanation. I reckon this was the interactive map I’m thinking of, it seems to only show Newcastle to Middlesbrough improvements as being along the coast, when you select Newcastle in the drop-down: http://maps.dft.gov.uk/northern/index.html
Half-hourly Middlesborough-Stockton-Newcastle is what it says, which is a big clue that Hartlepool and Sunderland MIGHT miss out.
Anvil1984
28 Aug 2010
On the Northern Connect part of the Northern site it states “Middlesbrough-Durham-Newcastle-Carlisle” which is a further hint the trains won’t be going down the coast
darloscott
12 Dec 2013
Stockton
There was also a suggestion that these trains will operate as 4-car 158s... with 18 units transferring to Heaton. Current journey times between Carlisle and Middlesbrough are around 3 hours, so assuming you could save some time on the Connect routing, that would suggest 12 units on a 6 hour circuit. That would give 6 spare units, so presumably scope for using 3 or 4 elsewhere - maybe Heaton will also take some S&C diagrams?
cuccir
18 Nov 2009
Back in May 2018, the three morning Saltburn/Middleborough - Darlington - Durham - Newcastle services were extended to Carlisle. I think that this is further support for the idea that the Northern Connect service (presuming it does actually happen) will run via Durham; I know they won't serve Darlington, but I can see these fitting in as a morning peak variation of the main route.
VT 390
7 Dec 2018
Could northern not run the new Connect service via Durham and then have a Half-Hourly local service running Middlesborough to Newcastle via Hartlepool and Sunderland.
sprinterguy
4 Mar 2010
Macclesfield
If they had sufficient stock then they probably could, but there are no plans for the latter during the course of the current franchise.
That doesn't seem likely, given that Neville Hill depot is conveniently sited at one end of the route and will continue to operate 158s. More likely that a handful of 158s will find themselves on non-Connect services, in the same way that they used to find themselves on non-TPE services in the north east back in the day.
