Increase in fare following railcard application
gabrielhj07
5 May 2022
Herts
Hi all,
Looking at Anytime returns from Ewell West to Box Hill & Westhumble at the TVM.
I see that using my 16-25 railcard sends the price up by £2.30, which is counterintuitive.
Could anyone shed some light as to what is happening here?
Cantab26
9 Jun 2016
Hi all,
A £12 minimum fare applies for journeys starting between 04.30-09.59 Monday to Friday excluding Advance Fares. This minimum fare does not apply on public holidays or throughout July and August.
matt
30 Jun 2005
Rugby
What time are you using the ticket machine? Looks like it is applying he £12 minimum railcard fare.
It is the £12 minimum fare before 10am. Clearly you would buy the ticket without the railcard if travelling then.
Hi all,
They shouldn't be offering a £12 minimum fare in a case like this, where the base fare is £12 or less. It literally offers you no benefit at all, indeed all it does is add a restriction, namely that you (or the person you transfer the ticket to) must have and carry a 16-25 Railcard.
Class800
5 Feb 2020
West Country
I've encountered this several times - it's just the minimum fare with railcard. Need to deselect railcard to get the normal fare
The reason it is like this is because there are reasons you may want to pay the higher fare, e.g. to allow accompanied children on a Network Railcard, or as a legacy of supporting the old Virgin "no peak restrictions on Railcard tickets" thing. It would be better if it only did it in relevant cases, but this is simpler to implement and manage.
There's no benefit with 16-25 Railcards though, and certainly not where the base fare is below £12 anyway.
gabrielhj07
5 May 2022
Herts
Thanks, using it at 0815 or thereabouts.
The minimum fare seems daft in this instance, but at least it doesn’t increase the standard fare!
How relevant would this be, given Virgin obviously never went to Epsom?
Rather than continuously manage which Railcards offered this and which didn't as TOCs added and removed promotions and Railcard T&Cs shifted, it was done for all Railcards and left like that. On all TVMs I have used recently you get a popup asking if you really want to pay the higher fare, so you can't be caught out by it unless you really are not paying attention.
It is relevant to Epsom if you want to get the hefty discount for accompanied children on a Network Railcard, by the way. Though really the minimum fare policy is a bit absurd here, it should really logically be "the undiscounted fare if it is lower", not to price it up in that way.
