Inconsistent escalator standing side in stations
Warrior2852
27 Oct 2018
I've noticed the rail network seems to be inconsistent on whether people should stand on the left or right of escalators at stations. For instance, London generally uses on the right, but Edinburgh uses the left. Glasgow meanwhile mixes and matches with National Rail on the left but the Subway on the right! This inconsistency only ever seems to cause confusion, especially when you get people used to the likes of London turning up to a station that uses the left but assuming it's the right so you have both sides used by locals and visitors. Why have things not been standardised across the UK's rail network? The current inconsistency of some stations in the country using the left hand side just seems to create more congestion from the confusion.
Tester
5 Jul 2020
Watford
We don't have a monopoly!
In Tokyo one stands on the left to protect your heart
In Osaka one stands on the right to protect your wallet
(Old Tokyo joke against materialistic Osakans!)
takno
Verified Rep - Traksy
I'm fairly sure you're just supposed to stand on the escalators in Edinburgh, and in most other places for that matter. The side you find yourself able to barge past on may just vary based on who got on the escalator in front of you.
The exile
31 Mar 2010
Somerset
Think the only place there’s actually a convention with signs is London (if others have appeared elsewhere, then I suspect it’s recent - indeed escalators other than at underground (note - small u) stations are a relatively recent phenomenon.
Classically Merseyrail also just had everyone stand, but in recent years the London practice of stand on the right and walk on the left seems to have been informally adopted. I guess people are more hurried these days.
cool110
12 Dec 2014
Preston
Not really, it's been signposted at the underground stations for a very long time.
Warrior2852
27 Oct 2018
The escalators up to Princes' Street I think are stand only (because there's a big staircase next to them) but the ones from near the Platform 12 gateline up to the overbridge I've definitely seen a "stand on the left" sign at at some point. And Glasgow has them quite prominently on both Central down to Low Level ("Stand on the left") and Subway ("Stand on the right") escalators.
takno
There's a lot of "keep left" signs there, but that's relating to where you should be walking on the bridge. If you want to get onto/off the bridge quickly at that point you're usually better off on the stairs anyway.
contrex
19 May 2009
St Werburghs, Bristol
At Bristol Temple Meads, the stairs hetween the subway and the platforms have 'keep left' on the the riser of each step on the left as you go up, and a row of little 'no entry' signs on the the right-hand steps. These seem to be widely ignored at busy times.
YorksLad12
5 Feb 2020
Leeds is stand on the right. But then...
The other week I was on the right and the two guys in front of me moved from the right to the left... because all the people in front of them were on the left. Then they saw the sign and moved back to the right. No-one was running up the escalator (don't get me started...) so it was all good. But very confusing that so many people all chose to stand on the left at the same time.
Tester
5 Jul 2020
Watford
Standing on the right in London is a bit strange, but very well established.
My experience around the world is that most commonly the convention is to stand on the side the country drives on (so UK on the left). There are exceptions, but the convention holds far more than it doesn't.
Dr Hoo
10 Nov 2015
Hope Valley
I have a feeling that at least some Scottish escalators were switched to ‘stand on the left’ during covid (to reduce the chance of people coughing the virus into the faces of those being whisked past in the opposite direction).
Peter0124
20 Nov 2016
It would be good if other cities adopted the London approach, maybe a bit more relaxed but there should always be an option to walk up/down an escalator free of needing to say excuse me or ask people to get past, especially if its a long one.
One of the only positives about London commuting is how efficient it is.
That is true as IIRC Glasgow Central was 'stand on the right' in 2019. They also have that silly one way system in place still on the low level, meaning you have to use escalators to go down rather than regular stairs, and one of the quickest entrances on the street is exit only.
I have mentioned the Glasgow Central stand on left thing a few times before but Scotrail said that there is no particular reason why it's like that. I still think it changed after covid.
The exile
31 Mar 2010
Somerset
Not helped by the fact that under COVID and for several years afterwards viewed from the perspective of the subway it was the entire staircase to the left for “up” and the entire one to the right for “down” .
contrex
19 May 2009
They still are, aren't they? Like this I mean... I see the 'up' risers have arrows, and not 'KEEP LEFT' as I said before
Hahahah... I did wonder about that!
Like the old joke - 'Crossing yourself? No, just checking I still have spectacles, testicles, wallet, watch.'
Beebman
17 Feb 2011
Twyford
I was in Kuala Lumpur last month and the convention there is to stand on the left (the side Malaysia drives on).
urbophile
26 Nov 2015
It's taken a long time to catch on at Liverpool Central. Moorfields is more disciplined London style.
D1511
29 Jul 2023
WCML N
Same right left convention in the Netherlands
"links staan, recht gaan"
Warrior2852
27 Oct 2018
Edinburgh does have a stand on one side sign but it was on the right, I'd misremembered the side. Which means though that, because of Glasgow being on the left, stations at two ends of the Central Belt lines are using completely different sides for standing, so commuters have to use both on their journey!
(Attached, an image showing a sign at Edinburgh Waverley saying to stand on the right of the escalator)
If one of them decides to do one thing then doesn't the other usually choose the opposite?
Non-station escalators, such as shopping centres, don't see to have any "lane discipline" at all, except maybe in London. I guess many of the clientele rarely use escalators in stations, or there's a general expectation that nobody's in a hurry.
Peter0124
20 Nov 2016
Shopping centres are completely understandable, but busy train stations should be different.
Furrball
9 May 2011
The Princes' street escalators are quite often just broken!
urbophile
26 Nov 2015
In most shops the escalators tend to be narrower.
takno
Interesting. Waste of time trying to get past people and their luggage anyway, might as well just head for the stairs. Some naughty people even use the right hand side of the stairs to speed up their journey.
AM9
13 May 2014
St Albans
... and then there's travelator standing. I usually take the right hand side to stand.
Dr Day
16 Oct 2018
Bristol
As someone who doesn’t have the best balance, and is right handed, I will generally naturally use the right hand side of any escalator or stairway.
Either way the practice of effectively only using half the capacity of the escalator by only having one person per step leaving the other for the odd person in a rush walking up always feels inefficient to me!
