Justin Smith
My N gauge Farish class 101 wasn't the best over isolated points and track imperfections and I remember reading somewhere that a guy soldered jumper wires in to improve it.
I was never convinced by the current collection wipers and checking with a meter on my Class 101 it seemed it was the current collection from the inside wheelsets was worse then that from the outers, though in the end I ended up putting jumpers to chassis from both wheelsets.
I tried to obtain some ultra thin wire but was unsuccessful. As it happens I concluded that the wire did not have to be insulated so I used single wire strands. They seemed fairly flexible but I put a coil (see middle pic) in each to try and minimise flex and therefore maximise length of service before they break.
The inner jumper wires soldered to the chassis (see pic) but the outers were more awkward to solder so I had to trap the wires behind the screwed on chassis "end plugs"
It has been a couple of weeks now and the current collection (and therefore slow running) on the unit really is very much improved.
