Impossible journeys
Tomnick
10 Jun 2005
How is "on the same line" defined? I'd consider the earlier example of Melton to Sileby to be perfectly valid, but they're no more "on the same line" than East Midlands Parkway and Tutbury & Hatton ('adjacent' stations via Chellaston) are!
Buttsy
20 May 2011
Hanborough
I think the definition is being taken as 2 consective stations that have a passenger service running through them both without passing through another station in the interim, but that's only my thinking.
trickyvegas
10 Dec 2009
Stalybridge to Guide Bridge is only possible by doubling back from Piccadilly. I just had a look on NRE for prices and they are showing an Anytime Single - Route Any Permitted - at £1.50 !!! Can anyone explain this?
thenorthern
27 May 2013
Isn't Lockerbie to Carstairs one but not Carstairs to Lockerbie.
Hapton and Burnley Manchester Road is one as well.
Eagle
20 Feb 2011
Leamingrad / Blanfrancisco
I assume you mean Willington (Wellington is in Shropshire).
And yes, they are on the same line, namely the Birmingham to Derby line. Peartree just happens to also be on the Stoke to Derby line.
dannypye9999
28 Jun 2013
Gorton to Fairfield, two stations next to each other yet no direct train in either way..
Meaning a person who wants to travel from Gorton to Fairfield would have to change at Guide Bridge then make a reverse journey. Cheapest ticket option from Gorton to Guidge Bridge would be to buy a single to Fairfield because you have to change at Guide Bridge anyway.
Eagle
20 Feb 2011
This is no longer true. Since the last timetable change, Rose Hill trains now call at both Gorton and Fairfield.
Altnabreac
20 Apr 2013
Salt & Vinegar
Motherwell - Uddingston not via Bellshill is only possible on 2 trains each way per day. Uddingston - Newton is shown on Scotrail's Lanarkshire route map but I don't think any services actually go that way?
nw1
9 Aug 2013
Norton Bridge to Crewe is one as well as Stoke-on-Trent to Rugeley Trent Valley via the Stone-Colwich line (one northbound London Midland train per day goes along that line).
Mind you does that count, because all trains from there (Norton Bridge) are actually buses?
It might not require any changes but it is certainly not direct.
We often refer to 'direct trains' but the official rule used in the Routeing Guide is a "through train", so if we're being pedantic, let's use that official term, and there can be no doubt! (People often use the terms interchangeably)
The opening post does not state they must be consecutive. We've had many threads asking about consecutive stations (here's an example: Consecutive stations with no direct service? )
As is often the case with these sort of threads, confusion is generated if the opening post is not clear. :|
I assume he meant to say, rather than "the same line", a route by which there are through trains? But then that opens up all sorts of possibilities.
If "the same line" was intentional then, I agree, we need a definition.
By "impossible" I guess he really either means "Not possible without doubling back" or "Not possible without catching 2 or more trains" (I am not sure which)
bb21
Emeritus Moderator
4 Feb 2010
You are correct that this is not possible.
Uddingston - Newton involves crossing from Newton East Junction to Newton (Hamilton Line) Junction, which according to PSUL has only one service in the eastbound direction, by Virgin, early Saturday morning only.
Cheds
29 Feb 2012
A couple of others
Oxenholme Carnforth
Melton Mowbray Loughborough
Melton seems to have a few of these.
11 Sep 2012
uk
There are trains in the morning from Loughborough to Melton, and an evening return on Nottingham-Peterborough services.
Cheds
29 Feb 2012
I may have to bow to eagle's superior knowledge here, but I thought there was track between Melton and Loughborough which doesn't pass through other stations? Eg for nottingham - east Anglian routes
Eagle
20 Feb 2011
No, that route passes through Sileby and Barrow-upon-Soar. (These stations are only served by the Leicester to Lincoln trains though.)
Might be that you're looking at an old map as those stations only opened in 1994.
9 Feb 2009
The station Eagle refers to are Sileby and Barrow-on-Soar. However if it is using the main lines (which I'm sure it does) then it won't pass through them as they are on the goods lines.
Eagle
20 Feb 2011
Well yeah, but by that definition a train only passes through a station if it's on a platform line, and that would invalidate a lot of the responses on this thread.
Trainfan344
13 Oct 2012
Glasgow to Bath Spa is impossible direct, but Bath Spa to Glasgow is possible direct.
