Immingham Signal Boxes
feldom76
7 Jul 2013
Hi,
Is it possible to photograph the 3 Immingham signal boxes from areas accessible to the public.
thanks
Mike
lincolnshire
12 Jun 2011
Hi,
thanks
Mike
Think you may be able to get a picture of Immingham Reception from a car park accessible from the main road. The others two are on the dock estate itself so not sure if they will let you in to get pics of them. Years ago it was never a problem anyone could drive across the dock estate then. There used to be a service bus that went on the dock, not sure about if it still does or not and there was a pub at the lock head they mat let you in to get to that.
Francis
22 Dec 2011
Chorley, Lancs
I went exploring last week, to take pictures of the north Lincs boxes before they are all abolished in the forthcoming resignalling works.
The IMG Reception Sidings box in blue can be seen by turning left off the southbound carriageway of Manby Rd A1173, onto a dirt access track,about 1/2 mile south of the roundabout where the A160 ends. You go over some gas pipes (I left my car near here) and then the track turns to parallel the railway and the box is 100 yds up on the right, across the lines. There weren't any No trespassing signs.
As to Immingham West Jc Box you have to drive into the port, amid the constant stream of lorries. Coming in on the A160, take 1st exit on the roundabout, go under the bridge, carry on straight along Humber Rd, through the port gate (nobody checked) and take the third exit on the roundabout onto West Haven way (see Google maps). This goes steeply up and over the railway. Straight on at next roundabout, and at the next roundabout, just after a level crossing, you will see the W Jc signal box straight ahead in some rough ground, strangely isolated from tracks.
Immingham E Jc I couldn't catch sight of. You carry on down the A1173 Grimsby direction, past Immingham village and turn L up Kings Rd which becomes Queens Rd. It climbs over a bridge over the line towards Grimsby, but the box lies back before the curve and wasn't visible from here. If you check the track diagrams you can get the mileage. It must be opposite the straight section of Queens Rd before the bridge, but there is thick undergrowth and it isn't visible. I tried following a track which led over gas pipes and the brook, but the rail fence was higher up, through thick undergrowth, and the box wasn't visible at all. If you have any success I'd be interested to hear about it!
GrimsbyPacer
13 Oct 2014
Grimsby
Are't Immingham boxes safe? I throught it was just the mainlinr ones being demolished.
Immingham Reception should be kept as it's very nice.
33056
12 Nov 2007
On a train somewhere in Europe
Don't forget that Immingham East is a rather anonymous "Portacabin" type structure encased in a secure compound now, not particularly photogenic:
The old box was much further away from any publically accessable locations:
Strangely enough, Google Earth still shows the old box which was closed three years ago!
Francis
22 Dec 2011
Chorley, Lancs
Many thanks for the info and pics. That explains why I couldn't find the old box! My track atlas and the Eastern track plans are well out of date and show only the old box.
Rich_D3167
14 Jun 2010
Hull
Two of the three Immingham Signal Boxes (West & Reception Sidings) are remaining as they currently are after this Christmas/New Year North Lincolnshire resignalling (ABP own these rather than Network Rail, so are unaffected apart from some slight alterations). East will close as a Signal Box, but will be retained as a "Token exchange point", as the Light Railway to Great Coates Sidings No.1 Junction is remaining as it is, so Electric Token Block will remain to Pyewipe Road Signal Box. As that line is only open "As & when required", East will only open when Pyewipe Road & Great Coates Sidings No.1 are.
