Looks to be on the up Goods just south of Kingmoor, so not top priority for relaying I would imagine.
No the picture looks like the main line out of Platform 3 looking north to me.
Unfortunately the heat transfer from a flat steel web to a circular cross-section tube will be minimal. Also I'm afraid the railway can't even maintain the kit it has now, let alone something new that will only be used a few weeks twice a year at most! Maybe better to install "simple" water sprays - except that they will only be needed for a week in high summer (some years) so the chances of them still working when needed are even less. And that's if there is a power and water supply available!Could you not clip PVC pipe to the side of the rail web,
Could you not clip PVC pipe to the side of the rail web, which could have water circulated through them to suppress temperature spikes during the summer? The water-antifreeze mixture could potentially be used during the winter to help keep point machines from icing up.
Apologies, should have taken closer look at satellite view.No the picture looks like the main line out of Platform 3 looking north to me.
Mr Locke, was it not yourself who invented that type of track?So, ... jointed bullhead on wood - nuff said.
I think the aspect restriction in SSI can only be done by the technician, although it would be possible to add more data so the signaller could operate a control that restricted all signals in a particular area to no better than single yellow for example.
It would also be possible to add switchable speed "boards", probably similar to theatre route indicators or the speed indications in German signalling which I think are clear enough to be visible to approaching trains at any speed. These could even, in theory, be enforceable by extra TPWS loops. However it would need a change to the rule book and would obviously be quite a lot of safety-critical alteration especially if the nearby trackside modules don't have spare connections.
Harumph. My error was even worse - double headed rail.
Tho' it pains me dearly, that Vignoles chap got it right, and we Brits comprehensively ignored him for nigh on 100 years. As if a continental could do better, I ask you; we go over there and tell them what to do and that's the gratitude you get. It's not as if UIC turnouts are a better design than RT60 ... ah ... err ... well .. what was I saying?
I also wonder if the traction and braking forces from all that slowing down and speeding up might not make the risk of buckling worse.Indeed. Temporary approach control (from red) can only be applied by the technician per signal (i.e. not per route from that signal). If it were to be used it would require a list of specific locations where a TSR was required for a signalling technician to then work out which signals would need restricting and then as a vital safety control would need checking to ensure the application met the TSR requirement. Therefore probably impractical from an implementation pov.
Yes. It's a long time since I did any SSI data but I think you'd put an if-then statement for each signal immediately after the aspect sequencing, setting it back to yellow if it is less restrictive than yellow and a certain latch is set (or perhaps unset). There would then be a panel request to set and to unset each latch, operated by a button on the screen.Restriction of aspects to a specific colour (e.g. yellow) is an altogether different problem. That can only be performed in bespoke data with presumably a corresponding application and removal device involving similar provision in the control centre software?
