I thought trains never departed early?
Krokodil
23 Jan 2023
Wales
Clapham Junction and Balham both have standing instructions for departing early for trains towards Victoria
Could do with that at Manchester Oxford Road and Manchester Piccadilly for services towards Manchester Airport. Would help ease a lot of congestion when trains start running out of their own paths. You'd probably have to make all trains stop at all five intermediate stations but that's no bad thing in my view.
Falcon1200
14 Jun 2021
Neilston, East Renfrewshire
Mechanical absolute block boxes often have signallers manually enter trains into TRUST as theres no automatic reporting in their area. They pretty much never end up majorly messing up anything to the best of my knowledge. I wonder why it would be any different in TCB areas with automatic reporting?
That's a fair point, but a Signaller inputting times manually where it is part of their normal routine is less onerous than trying to compensate for the loss of auto reporting, in a place where manual reporting is not usually required.
miklcct
2 May 2021
Cricklewood
I've found out that trains departing early is a way for an operator to minimise Delay Repay responsibility as it can usually lead to the actual delay being brought down a step.
I was hit by a cancellation yesterday, but after changing trains, because trains always depart when ready (i.e. early) at the interchange station, my actual delay was reduced to 14 minutes on a connection which runs every 15 minutes (Clapham Junction - Battersea Park). As a result no Delay Repay was due.
43066
24 Nov 2019
Trains only depart when ready at certain locations (Clapham Junction is one, London Bridge is another) because it makes sense to keep the service running towards the main terminal to minimise delays overall. It really isn’t done specifically to cheat individual travellers out of delay repay claims by one minute!
Mikey C
11 Feb 2013
Nobody cares about individual services on short and incredibly frequent routes like Clapham J to to Waterloo/Victoria or London Bridge to Charing Cross, as the next train will be along shortly.
It's not acceptable when the frequency is far worse. My example for example, where if I had missed the train at Highbury & Islington because it left early, I would have had a 30 minute wait.
greatkingrat
20 Jan 2011
Surely the answer is for the published public timetable to be one minute earlier than the working timetable…?
Problem solved or am I missing something?
That leads to its own issues, as previously valid connections will become invalid.
miklcct
2 May 2021
Cricklewood
If all the departures in the public timetable is changed to be 1 minute earlier if the working timetable is on the minute, by reducing all the minimum connecting time at all station by 1 minute, all valid connections will remain valid.
If the working arrival is on the minute while the working departure is on half minute, the public departure will be kept on the minute without change, i.e. all public departure times must be at least half a minute earlier than the working departure times.
185
29 Aug 2010
I've observed one station with CIS clocks 3 minutes fast. This hardly helps run a punctual railway.
43066
24 Nov 2019
But that reduces capacity, and people will get used to the train leaving one minute late, which makes no sense. What happens when complaints start to come in that the train normally leaves a minute late, but now it has left thirty seconds late (both on time according to the working timetable)?
There always has to be a cut off and I don’t see why it’s unreasonable for that to be that the train aims to leave at the booked time, but doors close 30 seconds earlier than that.
Is it really so unreasonable to expect people to be there thirty seconds before!?
Not St Pancras by any chance? If so, I completely agree, but the inaccurate platform ones aren’t followed for dispatch purposes.
Why is this better than saying, “departure is at 1300, but doors close at 12:59:30?” Having an effective two minute window at every station will reduce capacity and still lead to people cutting it fine and being left behind.
The point that is perhaps being missed is that, in order for a train to depart roughly on the minute, dispatch and closing of doors needs to begin 30 seconds before. That way the wheels start turning right time.
Esker-pades
23 Jul 2015
Beds, Bucks, or somewhere else
Yep; it's been like that at Milton Keynes for the past couple of weeks. Caught a few staff out and a hurried re-unlocking of doors. Not seen any early departures though.
Howardh
17 May 2011
In the Netherlands they used to (still do?) have + or - 1 min on the departure displays, so if you turned up with 45 seconds before your train, and it was leaving, then NS had covered themselves by this method.
That's my memory of it, could be wrong, can anyone confirm? Does seem a sensible option for a train to depart early?
bazzarati
4 Feb 2023
Ashford
The problem with manually inputting Trust times when auto-reporting has failed (I'm assuming that is what is being referred to here?) is that it would be all too easy to mistakenly input incorrect times. Manual interference with Trust reports, whether well-intentioned or not, is fraught with danger.
Regarding trains departing early, I can only say that as a rail passenger since 1971, and as rail staff in an operational role from 1984 to 2016, such instances were incredibly rare.
Could you expand on that. I don't see what the big deal is?
Falcon1200
14 Jun 2021
Quite simply, making a mistake and inputting an incorrect time, or reporting a time for a wrong train. Both of which have happened. And mistakes are more likely in a location which does not normally have to input manual times, this therefore being an additional duty at what is likely to be a busy time already.
Deepgreen
12 Jun 2013
Gomshall, Surrey
Yes these things do happen occasionally. Not intentional.
Unfortunately it's more than the very rare thing it should be, given the huge investment in clocks on stations and trains and in software.
The public timetable shows 30 seconds earlier, always to the minute.
Just checked our timetable PDF and it states 30 seconds before published departure, so in this case I'd say the crew are within their rights to close the doors at 10:09:30 for a departure scheduled for 10:10:30, as the published departure time is 10:10
Deleted.
Are those the only two? I would have thought several more London suburban stations would have this.
I completely agree, but it's too much common sense to be adopted.
You're not missing anything... except the TOCs want to advertise faster journey times (i.e. have their cake and eat it!)
It's been debated frequently before on this forum.
Yes, while increasing journey times through longer dwell times (brought on by excessive door release delays, etc), defensive driving and so on. As you say - cake and eating it.
bazzarati
4 Feb 2023
Ashford
I dispute that. Signallers are quite capable of putting in the correct time. For example, the signaller I was referring to above, threatened with disciplinary action, records the trains time for every train in the train register they have. It's absurd that he can record the time in the book but not apparently on Trust. I think the whole company is a shambles and the way signallers treated is disgusting. Many of us are reaching the tipping point. I know of signallers all handing in their retirement notices or resignation notices simultaneously to screw the company. People have had enough.
Falcon1200
14 Jun 2021
Of course they are - But like all of us, Signallers are only human and capable of making mistakes, especially perhaps if having to carry out an additional duty not part of their normal work, which was the issue being discussed earlier. Even when it is their normal work, errors are possible, for example reporting a train at its terminus point but inputting the time against a different train say 2 hours later, meaning that no further reports can be made for the train, whether auto or manual, because Trust now thinks it has finished its journey! I have seen that happen.
That's very sad to hear, makes me even gladder that I was fortunate enough to retire in 2016. Best of luck to you and your colleagues.
bazzarati
4 Feb 2023
Ashford
It is sad. It was never a great place to work, but I was always optimistic it could improve. I don't think that anymore, quite the opposite. Even the younger colleagues,a fair few are looking to move over to the civil service.
jhy44
7 Aug 2008
Marylebone (London)
It's very annoying when this happens at Clapham Junction with Victoria-bound trains. Sometimes trains leave a whopping 4 minutes early, and then there is a timetabled gap of 7 minutes (meaning an 11 min gap due to the early departure) until the next service is due, and that next service is then sod's law running 5+ mins late, resulting in 15+ min gaps in service in what is supposed to be an 'every few mins turn up and go metro frequency'. There isn't really any rationale for 'avoiding congestion' when the next train is 15 mins away; very clearly no danger of that. And the trains which leave early often end up standstill waiting for a platform outside Victoria anyway making any possible benefit to the practice void.
I understand the rational if there is a service right behind it but it's poor practice otherwise. It makes a mockery of having a timetabled departure time at all.
Krokodil
23 Jan 2023
Wales
If you're complaining about having to wait 15 mins for a train, you need to (what is the phrase the kids use?) check your privilege. Plenty of two-hourly services around here with connections that almost seem designed to just let the passenger see the tail lights of the previous train disappear.
Jimini
8 Oct 2006
Reading
You've clearly not been at Clapham Junction in the morning peak trying to get into town. It's a bit busier than what you're comparing it to in Wales...
Krokodil
23 Jan 2023
Wales
And? Waiting for 15mins is not the end of the world. Granted, the carnage at London Bridge the other week was a bit different...
I don't spend my whole life in Wales by the way. You should see what gets fed through the pair of through platforms at Manchester Piccadilly.
If there was a 15 minute gap in service at busy times, you may not be able to physically board the train.
Krokodil
23 Jan 2023
Wales
So you wait for the next one - which in the circumstance described above could well be right behind the late-running train.
Northampton
The platforms at Clapham Junction are not particularly wide and if trains are backing up 15 minutes then they could easily become dangerously crowded.
Jimini
8 Oct 2006
Reading
Vaguely connected -- I was on this 1452 XC service from Birmingham New Street to Cheltenham Spa last Thursday, and the 1459 GWR service was let out of the sidings too early by the signaller, so we ended up sitting outside Cheltenham for ten minutes waiting for the 1459 to get out of the way, so us (the 1452) could call at Cheltenham.
Tester
5 Jul 2020
Watford
And that is a connection I have done more than once (various hours) so would have been even more annoying.
boiledbeans2
15 Oct 2020
Another one today. It seems they sent the stopping service ahead of the express service. So the stopping service was departing early to avoid holding up the express.
