- Joined
- 14 Jul 2011
- Messages
- 20,281
Well, it appears that new calculations have demonstrated that the optimum point for a Severn barrage is far further down stream than previously projected.
It appears the location would be somewhere in the vicinity of Port Eynon-Ilfracombe.
Assuming that such a barrage is built, many concepts have called for the construction of coupled electrochemical works to absorb the energy generated by the project - as it is too brief to be of much use for grid electricity without an enormously expensive 'buffering' infrastructure.
The logical location for these facilities would be on the barrage itself - which will likely have a broad crest for construction reasons and will have the shortest possible connections between the works and the turbines that generate the electricity. (Such a facility would have power spikes in the range of 36GWe according to primitive projections I made based on its average power of ~9GWe) Putting the equipment out in the middle of the barrage would also reduce the complaints that 'pristine' terrain had been 'spoiled.
Although the material for barrage construction would likely be delivered by sea, the electrochemical facilities constructed on such a hypothetical barrage would almost certainly require rail access for the delivery of raw materials such as limestone and coke or the export of materials such as ammonia, ammonium nitrate, urea and similar.
So, what would be the best-value way to connect a Gower-Ilfracombe barrage to the rail network for industrial traffic?
I assume through rail journeys would be insignificant in a barrage so far west and what traffic there is would likely be better supported by a relatively minor road across the barrage.
So only a single ended connection is required - and to make it more interesting I will allow a credit for the local services a route can support (for instance a services to Ilfracombe on the southern shore).
So have at it.
So have at it.
