Hypothetical Scenario regarding boarding trains early
Peter0124
20 Nov 2016
At stations like Glasgow Central, most Scotrail trains are unlocked.
My scenario is - what are your rights if a member of ticket barrier staff doesn't like you entering the platform area early because the train isn't on the board yet? Is there anywhere in the rules that say members of the public cannot enter platform areas early even if they have a valid ticket?
You already know the platform and unit your train will be, and you want to get on early to setup gear and get the best seat.
Eg the inbound for your 13:35 service arrives 13:19, you board at 13:20 and it doesn't show up on the board until after 13:25. Is there any problem with that? Its much better being able to avoid the scrum or waiting in crowded areas.
I've not had any issue doing this yet but its incase someone were to object in the future.
Sun Chariot
16 Mar 2009
The dwell time beforehand, can also be for cleaning-staff's "once-over" - removing the litter - through the train (a regular sight at Liverpool Street, during my commuting years). Not so easy if people are already in the carriages.
As for occasional platform-alterations or unit-swaps: you'd be sitting in the wrong train...
hexagon789
2 Sep 2016
As for occasional platform-alterations or unit-swaps: you'd be sitting in the wtong train...
I've seen this a few times - Trainline (possibly other apps too) seems to give out expected platform numbers, with people taking it as gospel.
They board early, not unreasonable unless staff say otherwise or the cleaners are doing a run of the unit.
Unfortunately there's a set swap or Trainline is simply wrong and then their keeness ends up backfiring.
SargeNpton
19 Nov 2018
Who's to say that what the passenger thinks is an 8-car train is really two 4-car trains. They then board one of the rear four, when they really wanted the front train.
hexagon789
2 Sep 2016
Happens sometimes at Glasgow Central where a 4 or 6 becomes two 2s or a 2 and a 4, though far fewer splits/attachments these days than there once were.
Peter0124
20 Nov 2016
In my experience, sudden set swaps on suburban services are rather unlikely, but can happen. I'm always checking the headcode of my train on a signal map regardless.
saismee
20 Oct 2023
Absolutely, especially at big termini.
hexagon789
2 Sep 2016
Not totally full proof in my experience.
Had an amusing incident at Queen Street about five weeks ago, where reporting numbers changed between platforms 3 times due to one service being delayed, then set swapped to a different inbound service whose outbound was then cancelled.
Then that swap was rejected and a fresh unit from depot allocated.
Then swapped again.
Then swapped back and the cancelled service reinstated.
The public facing solution was to simply not put the platform allocations up until the last swap was made, about 5 mins before scheduled departure but before the unit arrived from Eastfield depot.
JamesT
25 Feb 2015
I don’t think there are specific rules that say you can’t, but there are rules regarding instructions from staff.
Byelaw 1 says you can be required to queue, waiting behind the barriers is essentially queuing.
Byelaw 12(2) says that staff can issue you instructions and you are obliged to follow them. If they tell you not to go onto the platform early…
andy33gmail
23 Mar 2025
cambridgeshire
I’m a bit of a hypocrite on this one
When I’m heading to London in the morning and an on time, I generally wait for the person next to me to get up, before then getting my backpack off the shelf and leaving in the last few
Often you’ll see a few plonkers getting in the way trying to force their way on whilst you do so.
Equally, when I depart from Kings Cross using Great Northern; it’s almost certain the train will be late, and almost certain the platform will be announced within 2 minutes of departure … I’d argue they should allow the minimum connection time of 15 minutes … so I always second guess in order to find a clean seat facing the right way, in the correct carriage for alighting
18 Mar 2007
North Oxfordshire
Had one the other day at Marylebone, where an inbound 2 car from depot was followed into the same platform by a 4 car from Birmingham. Those 'in the know' knew that the two units would be coupled together to form a 6 car back out to Birmingham, and boarded the ex-Birmingham unit as soon as passengers had alighted.
A Chiltern member of staff then ended up going through the train trying to kick them all back off, as apparently the trains are not allowed to be coupled when passengers are onboard (daft rule, since it's considered perfectly safe on most other TOCs!)
However, while they were attempting to do this, the doors were locked and the units coupled anyway, but it could've been a pain if the rule was actually rigidly enforced!
Under those circumstances, I can see why barrier staff would be instructed to hold passengers from the platform, though with the shared barrier line at Marylebone, it's not really possible, and I've never seen staff hassle people waiting on the platform early.
takno
Verified Rep - Traksy
Being able to find and read a signal map doesn't give you any particular rights. Ultimately if a member of staff tells you to wait, you pretty much have to wait. It's useful to have access to detailed information, but please don't use it to be a pain.
It can be a bit frustrating when the boards are slow to update, but the staff at Queen Street are rarely awkward. Plus late set swaps are fairly common at Queen Street, and the platforms are much nearer the concourse than at somewhere like Euston, so there are quite good reasons why staff might want to hold you back from a specific service at certain times.
Peter0124
20 Nov 2016
Would the member of staff be likely to use common sense? Especially if someone is clearly autistic, likes to board early to pick a particular seat or get ready for the journey and isn't getting in the way of anyone.
Dr Hoo
10 Nov 2015
Hope Valley
A member of barrier staff may well not be aware of the precise status of any empty unit in a platform.
Somebody may have reported a suspicious package left, a soiled seat, passenger stuck in the toilet or whatever.
“Common sense” will include not allowing passengers to board until a train is fully ready.
Not all characteristics are visible or ‘obvious’.
saismee
20 Oct 2023
During my brief time at Liverpool Street, I would always set all of the gates in my array to exit when there was ECS/no departure for a while. No issues to be had, if someone really needed to access the platform then they could ask or walk to another array and enter from there. This obviously doesn't work for unbarriered platforms. I was never told if the unit was being shunter or cleaned, I just looked at the departure screens and signal map like the passengers do.
kw12
12 Jan 2017
At Manchester Piccadilly on Wednesday evening the gates for the low numbered platforms were all wide open. I and many other passengers boarded the train in platform 2 which was displayed on the station's passenger information screens, on the train itself and on RTT as 20.33 to Hadfield.
About four minutes before the scheduled departure time it was suddenly announced that there was a platform alteration and this service would now depart from platform 4 ...
If the staff member says no, they say no, and you are obliged to abide by it. That's the long and short of it.
Falcon1200
14 Jun 2021
Neilston, East Renfrewshire
At Glasgow Central I use Realtime Trains to find my train's booked platform and wait nearby but do not pass through the barriers until it is advertised; I know from my Control experience that diagrams can be altered at short or no notice, having arranged many such moves myself! What is annoying however, with my service, is only advertising the platform as the inward service is arriving, so both arriving and departing passengers are trying to use the barriers simultaneously.
Trainfan2019
9 Aug 2019
I'm guilty of wanting to board early. Diagnosed Asperger's and I only prefer certain seats, hence wanting to be onboard quickly. However, if for any the train is not unlocked then I have to accept it. I don't like it, but it doesn't send me into a meltdown.
Carntyne
8 Jul 2015
It all depends. Being autistic doesn't give a pass to board when you want though.
Must admit this is something that really gets my back up. I was at King’s Cross recently and my (valid) ticket was rejected by the barrier as is common on GTR, the member of staff then refused to allow me through on the basis that no train was advertised for the platform. Okay, I can quite happily walk round via the footbridge and platforms 8/9 then, and if staff can’t carry out basis tasks then there’s isn’t much point in wasting tax on them being there, and I made my views on this very clear to her.
Dr Hoo
10 Nov 2015
Hope Valley
Worth noting that many (if not all) bus companies have Conditions of Carriage that state that passengers must not board without the driver being present.
takno
In general I don't think the staff at Queen Street are very likely to stop anybody passing through the gateline, particularly if they have a ticket which scans, so the situation isn't very likely to come up.
If they are stopping people though then it will, at least in their mind, be for a good reason, and they probably won't appreciate being challenged on it. Sunflower lanyards or similar might trigger some staff to be adaptable, but I wouldn't necessarily assume they will. For me the discomfort of having a potentially difficult discussion with the person on the gateline would be more upsetting than any benefit, but I appreciate that YMMV.
In practice if you are waiting at the gateline in roughly the right place and keeping an eye on the boards, and you are ready to walk reasonably quickly, then most times you would get your preferred seat anyway.
Obviously this still leaves a small chance that you won't get the seat you want, and that you won't be settled in. You'd really need to assess if this is a situation you will be able to manage or not. If you believe you won't then it may be worth talking to Scotrail customer services in advance of travel to see if they can make reasonable accomodation.
sharpener
4 Oct 2018
IIRC there were several posts on here about drivers/station staff at Norwich leaving trains unlocked for long periods of time, with various unfortunate consequences.
But conversely the drivers will leave a bus already full of passengers unattended while they go in search of their relief, or will deny boarding until well after the advertised departure time bc they want to read the paper.
saismee
20 Oct 2023
Can't even seal the platform off as it's one big gateline for all 6 platforms. I personally dislike how trains are left by drivers on our network as it will sit there saying "Norwich" with no extra context, and unfortunately passengers are too stupid to read the actual platform and board anyway. My train is on 5A? Must be this empty train sitting on 5B! The trouble is that the previous driver doesn't know the next working unless it's booked to shunt and platform staff are ready to lock up. I still think we should be designing for the benefit of "below-average intelligence" people as they are unfortunately half of our population. If trains were left as "Not in service" then it would absolutely certainly be the passenger's own fault, even if left unlocked.
Dr Hoo
10 Nov 2015
Hope Valley
Yes, but I was referring to the bus operators’ Conditions of Carriage, not the behaviour of individual employees.
One should never extend lax enforcement or inconsistent application to a ‘right’ that doesn’t exist; as expressed by the OP.
Falcon1200
14 Jun 2021
Personally I am wary of entering a platform before the incoming service (identifiable by such as Realtime Trains) has arrived or the platform has been advertised, unless of course there is no other platform the train could possibly use; Which is not the case at Glasgow Central as per Post #1! I arranged far too many set swaps at that very location.
