Our new ticketing site is now live! Using either this or the original site (both powered by TrainSplit) helps support the running of the forum with every ticket purchase! Find out more and ask any questions/give us feedback in this thread!
Unless you have access to a new site for the Arena, I assure you that Victoria is not going to be expanded.
"Sorting out" Castlefield is a good number of generations in the making, and a good number of generations yet to come in the realisation of any solution.
Exactly. If the tunnel is built, I expect that the CLC (if converted) plus the ex-heavy rail lines from Altrincham & East Didsbury would use the tunnel. They would then flow on to Glossop, Rose Hill & Bury. Tram-trains might also run on the Altrincham, Bury & East Didsbury lines but those would run on to the city centre on-street lines rather than through the tunnel.
Potential light rail metro lines that could feed in to a tunnel:
Warrington
Glossop & Hadfield
Atherton
East Didsbury
Altrincham
Rose Hill
The remaining lines would see the tram-trains because they will share tracks with metro trains, i.e. metro trains run from East Didsbury, but between Chorlton & Cornbrook, tram-trains would also run on the line because in Wythenshawe and the city centre they would be using on-street lines.
Getting back to the original topic, I always thought it was a shame the Ashton-Oldham and Oldham-Greenfield lines were closed. If properly linked rather than retaining the pre-1923 service patterns, these could have formed a loop off the Transpennine main line. Semi-fasts could then run via Oldham and perhaps be overtaken by fasts via Stalybridge. The same could have been done with a route via Failsworth instead of Ashton, but that was always more suburban and slower trains would have been a problem.
Unfortunately both routes are now thoroughly lost, the most obvious problem being the housing estate between Lydgate Tunnel and Greenfield.
We are aware of an issue with emails from the Forum to Microsoft-based email accounts (hotmail/outlook/live.com email addresses). This is being looked into currently, thanks for your patience meanwhile.
