Hull to Thirsk via Leeds
mikeg
20 Apr 2010
Selby
My dad, who does not use trains very often, has had to make a journey from Hull to Thirsk for work purposes. He narrowly missed the 1503 departure to York and was advised by booking office staff to travel to Leeds. I had advised him to get the hull trains service to Donny and travel back to York, which is what the journey planners showed. However the ticket office seemed to think this would be quicker. Having checked the routeing guide it would appear there are no longer mapped routes via Leeds although its clear there once were. I used to do this route now and then a few years ago and it used to be suggested by the journey planners. Curiously there is a negative easement barring passengers with not Doncaster tickets from travelling via Leeds to York, so thus redundant easement would also suggest it was once a permitted route. I'll see his he gets on, but does anyone think he will have any trouble? I will probably write an appropriate foi request to daft when I get back from work.
rratgerg
21 Feb 2008
You cannot travel from Hull to Thirsk via Leeds on a single Hull to Thirsk ticket.
Hull is a routing point.
The only appopriate routing point for Thirsk is York.
Maps for Hull to York are DS, HA, YA - none allow travel via Leeds without doubling back
No easements apply.
mikeg
20 Apr 2010
Selby
I know you can't but sure it used to be allowed. He was given the advice by Hull ticket office and had no problem using his ticket this way, which suggests some customary acceptance even if its not official. As I say, I shall be writing to ask why this route is no longer allowed. Does anyone know if it was a permitted route in the first routeing guide/pre privatisation?
Incidentally, as far as doubling back goes I thought there was a permitted double back between micklefield and Leeds under the group stations rule, at least previously. However now it is impossible to trace a map from hull to Leeds without first going thru Doncaster or York, therefore no longer valid.
rratgerg
21 Feb 2008
Hull to Thirsk is not valid via Micklefield. The latter station is part of the Leeds Group and so doubling back within the Leeds Group is allowed on journeys where Leeds is on the permitted route, but as we've said in this case it is not.
mikeg
20 Apr 2010
Selby
Thanks for all your help. I am sure there once was such a route, or at least the journey planners used to show this route unless my memory is playing tricks on me. I have submitted a Freedom of Information act request to daft to find out if and when this route ceased to be valid.
rratgerg
21 Feb 2008
I agree that easement 700479 "Customers travelling from Hull to York in possession of tickets routed "not via Doncaster" may not travel via Leeds. This easement applies in both directions" is redundant and so does imply that the route was once valid.
kieron
22 Mar 2012
Connah's Quay
There's an unofficial web site with old versions of the routeing guide here. The 2013-02-14 version of the permitted list route includes TP as an option for Hull-York, a map which only permitted travel via Leeds. This shows that someone wanted Hull-York to be valid that way at some point. The route was dropped in the following version, and the route via Leeds certainly hasn't been on a map since 2014-04-16.
The 1996-08-19 version just gives ER for this route, a map which included routes via Leeds, as well as ones which avoid it.
Looking elsewhere on the site, Hull-York used to have "direct" fares, which were later replaced with "not via Doncaster" ones in 2009. I haven't checked how old the easement is, but it may have been something to do with that change. Hull-Thirsk has only had "any permitted" tickets.
Just get a couple of FOI requests in:
One to the DfT asking if they gave permission for the via Leeds mapped routes to be removed, and if they did, why did they do so? If they did not, then what action have they taken and will they be taking against ATOC?
And another to Passenger Focus asking if they were consulted, and what their response was.
You could use http://whatdotheyknow.com/ if you wish.
I suspect DfT will say "We were not asked" in which case it's an unlawful change.
Let us know what response you get
mikeg
20 Apr 2010
Selby
I've received a response from the DfT as follows:
Dear Mr G*,
Freedom of Information Act Request – F0014691
Thank you for your Freedom of Information (FOI) request of 23 March 2017. You requested the following information:
1. I would like to know at what point Hull to Thirsk via Micklefield/Leeds ceased to be a mapped, permitted route in the National Routeing Guide.
2. I would like to know did the Department for Transport approve this change. Were Passenger Focus/Transport Focus consulted?
3. If the change was approved, may I see any relevant correspondence between the DfT and ATOC? Also if Passenger/Transport Focus were consulted, what was their response?
Your request has been considered under the FOI Act 2000. The Department for Transport (DfT) has now completed its search for the information.
I am writing to confirm that following a thorough search of our paper and electronic records, I have established that the DfT does not hold any information on the ceasing of Hull to Thirsk via Micklefield/Leeds being a mapped, permitted route in the National Routeing Guidance.
However, in order to be as helpful as possible, I should advise that the National Routeing Guidance is administered by the Rail Delivery Group. You may wish to contact the Rail Delivery Group on this matter and contact details can be found here: http://www.raildeliverygroup.com/contact-us.html
If you consider that travel from Hull to Thirsk via Micklefield/Leeds was previously a permitted route, you may also wish to consider contacting Northern Rail in order to instigate the Disputed Routeing Procedure, as set out in Section A of the National Routeing Guide which can be found here: http://data.atoc.org/routeing-guide
***PERSONAL DETAILS REMOVED***
Ms M Dkik Correspondence Manager Department for Transport Great Minster House 33 Horseferry Road London SW1P 4DR
Web Site: www.gov.uk/dft
Our Ref: F0014691 21 April 2017
Northern Rail can be contacted at the following address:
By post: FREEPOST Northern Railway
E-mail: enquiries@northernrailway.co.uk By phone: 0800 200 6060
If you are unhappy with the way the DfT has handled your request or with the decisions made in relation to your request you may complain within two calendar months of the date of this letter by writing to the DfT’s FOI Advice Team at:
Zone D/04 Ashdown House Sedlescombe Road North Hastings East Sussex TN37 7GA E-mail: FOI-Advice-Team-DFT@dft.gsi.gov.uk
Please send or copy any follow-up correspondence relating to this request to the FOI Advice Team to help ensure that it receives prompt attention. Please also remember to quote the reference number above in any future communications.
Please see attached details of DfT’s complaints procedure and your right to complain to the Information Commissioner.
Yours sincerely
Ms M Dkik Correspondence Manager – Passenger Services
Have to say I'm rather disappointed, the questions seem rather glossed over, especially since other forum members have stated it was valid in the original routeing guide and at the time of privatisation. If they don't know about it though surely the change was illegal as they weren't told, funny they don't seem too bothered about that. Odd that they suggest invoking the disputed route procedure with Northern, not TPE. Any advice on how further to progress with this?
Any removal of permitted routes must be authorised by DfT for the removal to be lawful.
Therefore any attempt to deny travel via this previously permitted route would not appear to be lawful.
You could now write to ATOC insisting on the reinstatement of these routes and also to the DfT thanking them for confirmation that they did not give permission for the withdrawal of the routes and for enforcement action to be taken against ATOC.
I do agree it is worth contacting both Northern and TPE, and I'd add VTEC. You could ask each if they requested the change and , if not, were they consulted, and would they consider asking ATOC to reinstate it.
You may want to write to any relevant MPs about this matter.
mikeg
20 Apr 2010
Selby
Thankyou for your prompt reply, I will probably have written to ATOC and a reply to the DfT by Monday evening at the latest (my next day off work) if not earlier, I'll have a think about wording. I was thinking maybe of contacting the Thirsk and Northallerton station users group, something which I know exists but have not yet been involved with as this often has local politicians and TOC reps present and maybe they will take an interest?
