If you're travelling in one day, and willing to be restricted to the Penistone line, the cheapest is as follows:
Huddersfield-Sheffield £4.75 CDR
Sheffield-Derby £8.60 Derbyshire Wayfarer
Long Eaton-Loughborough £3.30 SDR
Total = £16.65
Note the following though:
- You will have to leave after 10am M-F to avoid the 16-25 railcard minimum fare. At weekends you can leave as early as you like!
- The Wayfarer is available from Sheffield station.
- You will have to catch a service that calls at Long Eaton (shouldn't be a problem mind, most Sheffield-Loughborough services do).
if that £4.75 ticket is the £4.90 "Not Leeds" one then you can go via Wakefield Westgate by using the Selby-Wakefield Wesgate via Leeds,Bradford and Huddersfield "Grand Tour" service which leaves Huddersfield for Westgate at around xx35
= £16.65
Another ticket option for travel if coming back same day is
Huddersfield-Chesterfield Standard Day Return £6.65
Chesterfield-Loughborough £10.70 Off Peak Return
Total £17.35
or if not coming back on the same day
Hudderdfield-Chesterfield Standard Open Return £7.75
Chesterfield-Loughborough Off Peak Return £10.70
Total = £18.45
Gives a Slight Saving.
