HSTs replacing Voyagers for the Cross Country services.
Philip
27 May 2007
Manchester
With many redundant HST sets soon to be available, should CC consider taking them on to replace their notorious Voyager fleet?
It'd mean longer trains, better fuel efficiency, arguably a more comfortable experience for passengers and a bit more interest for enthusiasts. So why not?
Philip Phlopp
31 May 2015
The HST stock that's left is rotten, they're plagued with corrosion problems, the underfloor skirting is patched together, the engine blocks in the power cars are close to being life expired, the electrics are pretty much shot, they're not DDA compliant without a fabulous amount of money being spent on them, and I'd fully expect the RAIB to have a little something to say about the garden shed bolted onto the front of the power car that BREL laughingly called a driver's cab, when they publish the full Stonehaven dossier.
Yes, they'll cost half as much as buying in Hitachi AT300 stock, but with a quarter of the life expectancy if you're lucky.
So yes, lots of why nots.
Dr Hoo
10 Nov 2015
Hope Valley
Could you provide some figures to support your fuel efficiency claim, please?
43096
23 Nov 2015
This again. How many times have we gone over this now?
py_megapixel
5 Nov 2018
Northern England
Voyagers are best part of 30 years newer than HSTs, you'd have to pay to PRM mod them and they'd need an interior refurb too to get them up to same standard. Plus as @Philip Phlopp said some of them are in rather poor condition.
They were great when they were introduced, I'm sure, but they've had their day, and enthusiasts are unfortunately just going to have to accept that.
Philip
27 May 2007
Manchester
One huge engine vs 4 or 5 very big engines which aren't fuel efficient in themselves. It's obvious the Voyager will consume more fuel.
DB
Guest
18 Nov 2009
Clearly, if this was going to happen it would have done so before loads of Mk3s were scrapped. It's therefore petty safe to assume that it's not going to happen - and the suggestions were always that they would be in addition to Voyagers, not instead of.
py_megapixel
5 Nov 2018
Northern England
With all due respect, why are so many people so obsessed with reusing the 43s?
They're approaching 50 years old and not in good condition. The route for them is preservation or scrap.
No they shouldnt. My prediction is that XC will take on a significant number of the soon to be off-lease 221 and 222, and it’s actually far more likely they’ll bin the HSTs they have already got. They can go to the West Country or Scotland and find use on secondary routes
But the whole subject has been covered numerous times already this year, how have you managed to miss all the previous discussions?
yoyothehobo
21 Aug 2015
I think we have been unkind and there is plenty of use for them yet...
It most likely wont be train shaped though
A0
19 Jan 2008
Not necessarily true - it also depends on the load and the way such engines are used.
So if by having 2 engines you are having to work them almost flat out, whereas the lesser engines can be used at 2/3rds then the latter are likely to be more fuel efficient.
LOL The Irony
29 Jul 2017
Chinatown, New York
Not necessarily, just watch this. (For reference, a 5 car 221 has 95 liters of displacement running at once vs 75ish in a HST)
the sniper
4 Sep 2007
I wasn't aware the service being interesting for enthusiasts was a key target of the railway network or TOC's.
They make up a far greater proportion of passengers than prior to 2020! Maybe it should be? :lol:
The Ham
6 Jul 2012
It reminds me of someone who was on Dragon's Den and listed two (fairly small) groups who might be interested in their product and then said "the gift market" as if that would increase the numbers significantly beyond the already listed groups.
In reality most being brought as a gift would be because the feel into the other groups.
Likewise most enthusiast travel is either work related or because they are going somewhere for leisure. The fact that they choose to holiday so that they can use a certain line or service is neither here or there as they aren't just traveling for no reason.
Yes some do, but it's fairly limited.
Pete_uk
28 Jan 2017
Stroud, Glos
So you're not fully ruling it out as a bad idea then?
fgwrich
15 Apr 2009
Hampshire
Should we kill two birds with one stone and suggest 442s for XC too? Between HSTs for XC and 1001 uses for the 442, they seem to be this forums must suggested stock for solutions that barely exists.
43096
23 Nov 2015
There's a few 365s and Mark 4s sat around as well!
In fact why not go the whole way and say 442s and Mark 4s with HST power cars...
py_megapixel
5 Nov 2018
Northern England
In fact why not go the whole way and say Mark 4s with HST power cars...
Nah, how about fitting diesel engines to 442s and using them to replace Turbostars? Now that's an idea worthy of this forum...
43096
23 Nov 2015
I knew there was a reason why the engines in the Northern Irish DEMUs shouldn't have been scrapped.
CBlue
30 Mar 2020
East Angular
Perhaps the engines from scrapped HST power cars can be fitted to the 365's while we're at it? Perfect replacement for Voyagers.
Philip Phlopp
31 May 2015
That will be quite difficult, given the Class 365s are to be converted into tri-voltage units. Two driving vehicles will be removed from a pair of units leaving six vehicles, one pantograph/transformer vehicle will be converted to have a 1500V DC compatible pantograph and associated switchgear will transform the 1500V DC to 750V DC and connect in with the existing 750V DC bus. This will enable them to operate services shared with the Tyne and Wear Metro.
ABB125
23 Jul 2016
University of Birmingham
Are you sure? I heard that the class 365s were being shortened to 3 cars (for speedier performance), and the pantograph and associated stuff being replaced with 755V wibble generators (the extra 5V makes all the difference!).
Whilst the vehicles removed from each set were going to be inserted into the class 442s to provide additional seating capacity on the West Highland line (electrified with two sets of third rail for double the power)? Assuming of course that the single motor car has enough power to shift five trailers, especially when the traction motors are replaced with those from scrapped class 313/314/315 units on a 3-for-2 basis!
:D:D:D
Clansman
4 Jan 2016
Also let's not forget the set in stone law of the land that stipulates that the Mk5s and IETs are the compulsory natural successor for anything IC, LHCS, or HST replacement!
37424
10 Apr 2020
The idea that your going to replace much newer trains that comply with accessibility legislation with much older trains that require significant amount of money to make them compliant is laughable really.
Anyway despite Scotrail with a fleet of 20 Voyagers spare in a couple of years time I don't imagine any other destination than XC
