xfileswilly
- Joined
- 7 Sep 2009
- Messages
- 9
I cant believe that only one person was injured and no one killed with that sort of damage, still most of the damage is to areas made of fibreglass.
I gave this answer several days ago but it seems most people are/were in denial and gibbered on about other (non)possibilities. Next time I won't bother and will leave them to it.![]()
I wasn't disagreeing with you in any way etc., merely informing what I've found out seeing that I've found my HST book, & backing your report up, that's all. :roll:
almost allmodern units have some sort of buffer system underneath the smooth fronts. just in case collisions happen
They're not that modern any more but they are units (Cl. 253 and 254 DEMUs).
Prepare for several pages on why they are/aren't units...
The only time a HST can be considered a Class 253/254 DEMU is when it's formed with its original power cars e.g. 43001 and 43002 form 253001. Other than that, an 'InterCity 125' is loco-hauled stock, the end![]()
EDIT: It could also be said that Grand Central have a '255', that is a 2+5 HST whenever 43067 and 43068 form the same diagram![]()
Right, I can't be bothered with a long post, so I'll just list.
HSTs are units, always have been, always will be, and this is why;
- The powercars cannot work in multiple with any other train without prior modification (ie. when they were used as stand in DVTs)
- They are semi-fixed formation DEMUs, classes 253/254, the reason for not using this is because they're semi-fixed, and the sets do not stay the same, so if they did use these, the numbers would be different at each end of the train. Would the DMS of a sprinter become a class 57 if they were semi-fixed, the sets changed around and the 156XXX codes on the front were no longer used?
- The powercars do contain passenger space, but in the form of luggage space. If you don't think this is the case, why is the 419 an EMU and not a loco?
- The Mk3s within the HSTs are Trailers, ie. TS being Trailer Standard, as opposed to LHCS mk3s which are TSOs or Tourist Standard Open.
- The TOPS codes on the side are coaching stock TOPS codes (like the 52XXX and 57XXX on the sides of a 156), and the whole DEMU is within the 4XXXX range of codes; the TFs are 41XXX, the TSs are 42XXX and the DMBs are 43XXX, etc. and I don't see you calling the TFs class 41s.
Decided not to get involved in this one, again..... So not debate(Arguement really!) from me. However, I will say I disagree with what you have said....
2+5 HSTs make a 255? Noor, I don't think so.
Your answer comes from Wickipedia which in this case is wrong.British Rail considered the HST, a fixed formation train with a locomotive at each end, as a multiple unit on introduction, and numbered them as such: 253 xxx (Western Region) and 254 xxx (Eastern and Scottish Regions). However, because two power cars carried the same 'set number', problems arose when for servicing reasons different units were used on a train, which would then display a different number at each end. For this reason, British Rail abolished the initial numbering system and all individual power cars became identified as such, using the format 43 xxx - this number was previously carried in small digits in the bodysides, prefixed by a 'W' or 'E' to identify the region, thus the power cars were reclassified as Class 43 diesel locomotives.
Thus, they are not classed as units, they are individual locomotives at each end of a fixed formation of coaches.![]()
it is labrooke grove, the wikipedia article names the power cars, 43018+43011, but then again wiki could be wrong
[*]The powercars cannot work in multiple with any other train without prior modification (ie. when they were used as stand in DVTs)
Has anyone thought that a HST is neither? In train planning, there is: Units, Locos and HSTs.
In my view HSTs are HSTs and not Locos or Units.
I'm not fussed whether people share my views or not, but they're mine.
