The only issue I see here is that you're not able to run trains to Liverpool, which is one of the stated aims of HS3. I guess some form of service into Piccadilly might be ok, but I think as a whole, the bulk of the service will go through Victoria, with the Piccadilly trains served via the Ordsall Chord.
Yeah, good point, I remembered that after I posted. For Liverpool, after Ashton Under Lyne, instead of turning left to go past Etihad and into Picc, go straight on and head into Victoria, then use/upgrade existing lines to Liverpool.
Through trains (Liv/Man/Leeds/Hull) would go to Victoria with Manchester - Leeds / Hull shuttles from Picc
Do you have a link to any info on the Neubaustrecke, this seems interesting? I think I get what you're getting at and it seems a reasonable compromise between following existing routing and creating a new line.
Why yes -
http://en.wikipedia.org/wiki/Köln–Frankfurt_high-speed_rail_line
This one shadows the motorway (rather than an old line)
Up to Batley and just north, this makes sense, i'm a little worried about what you'd do between the new flying junction North of Batley and the Gildersome tunnel. The original line towards the Gildersome tunnel was the LNWR line, whereas the GNR line ran towards Birkenshaw and Low Moor. There's also substantial development around there. I guess a new alignment through some fields might be possible, but given we're doing a lot of work to reduce curvature, this might undo all that hard work.
I've researched this are fairly well having lived in Morley for a fair few years. You are correct, however there would need to be a short "cross track jnc" to join across the two old formations. The thing is, in Batley, there is lots of space for extra track and if you follow the line up the embankment, over the mainline to Drig/Adwalton, vere off before Howden Clough/Birstall (as this are has been built on) and follow the valley towards the gildersome tunnel.
This all makes sense and looks reasonably feasible.
Cheers fella, I only really know the kirklees/WY - Picc part of the route so other will have a better idea about Leeds - Hull + Manchester - Liverpool.
Kirklees/West Yorkshire to me is the most interesting place in terms of old railways and there is a great website that documents it all
