The East West Railway bridge over HS2 at Calvert has been lifted into place - pictures here:
https://mediacentre.hs2.org.uk/reso...to-warwickshire/calvert-east-west-rail-bridge
Most of the EWR approach embankments have still to be constructed.
Construction of the HS2 Calvert cutting continues below the new bridge.
The HS2 construction and maintenance depot will be built in the north-east quadrant between the lines.
Two of the UK’s biggest infrastructure projects celebrated a joint milestone this week after a new bridge - that will carry direct rail services between Oxford and Cambridge - was lifted into position over the route of HS2, the high speed rail line under construction between London, Birmingham and the North.
Engineers working for HS2 used an enormous 600 tonne crane to lift the new bridge into position north of Aylesbury, Buckinghamshire.
The bridge deck - which weighs the same as 25 double decker buses - will carry East West Rail services linking Oxford, Bicester, Bedford and Cambridge, largely along a route that was closed in the 1960s.
