Hs2 operating speed?
Joshrowlands
19 Dec 2014
Stoke on Trent
Hi guys, I'm 19 and since the start of this year I have had a large interest in trains and the rail network, I know quite a lot but not as much as a lot of people I have a lot of questions of which Google can't answer no where near as good as members on this website.
I'm quite interested in hs2 I know quite a lot but I've heard about a thousand different things about it and I just don't know what's true, what will be the operating speed? If someone could give me a detailed answer that would be great also I'm more accustomed to mph than kph.
Also I've heard that at be start it will be a certain speed then it will increase as the years go on? Is this true and if so why not just operate at maximum speed from the start like I said detailed answers would be great guys thanks
NotATrainspott
2 Feb 2013
You don't need to preface your posts with your little bio. Most people on here read most things and will recognise your username and remember your 'story'.
The design goal speed of the HS2 infrastructure is 400km/h (250mph). The engineering companies HS2 Ltd contracts to plan and design the routes try to achieve this for as long as possible in as many places as is reasonably possible, but in various places and for various reasons the maximum main line speed drops down to anywhere between 360km/h (225mph) and 190kmh (120mph). Much of the route through South Yorkshire is limited to 360km/h due to the hills, with the 190km/h limitation being at Sheffield Meadowhall due to the lobbying efforts of the Firth Rixson metal company as the route can then avoid their factory. In general, there are greater speed restrictions on the eastern arm of the Y network from Birmingham to Leeds than there are anywhere else as the route passes through hillier terrain and through more populated areas. The western arm is mostly 400km/h, including the high speed bypass tunnels underneath Crewe, other than a 300km/h (186mph) section necessary to weave between the Greater Manchester and Merseyside towns.
As the route approaches its termini the speed will obviously decrease as trains have to decelerate anyway. The highest possible speed for a train taking the diverging route at a set of points is 230km/h (140mph) so all spur routes (into Birmingham, Manchester and Leeds) are limited to this, as is the first few kilometres of the eastern arm of the Y. The speed drops the closer the route is to London as well, with the viaduct across the Colne Valley (north of Heathrow) limited to 320km/h (200mph) and the tunnels on either side limited to around the same. Above 230km/h, it is necessary to increase the diameter of the tunnel due to aerodynamic effects so the cost will increase and more spoil must be disposed of, so if the case for a higher speed tunnel is marginal from a journey time perspective it is unlikely to be built.
These speeds are the maximum the infrastructure is designed to be used at every day. It might be possible to run faster for the purposes of high speed testing, but they will never be exceeded by normal services. At this point in time, it is possible to purchase high speed train sets with a maximum everyday service speed of 360km/h and this is what HS2 Ltd predict will be done. However, the normal operating speed that the timetable is written for will be only 330km/h (205mph), with the 360km/h capability of the trains being used only to make up time if there are delays. On lower speed sections, the normal operating speed will be reduced similarly up to a point. One of the reasons that the infrastructure speed is specified to be higher than what is possible to run every day with current technology is that there is experience around the world to say that train technology can advance to the point where those speeds are useful and possible. For example, the original Tokaido Shinkansen between Tokyo and Osaka is only normally capable of 270km/h (170mph) as it was built back in the 1960s, with the initial fleet of trains only running at around 230km/h. As modern trains are more than capable of running at >300km/h now, new rolling stock that is capable of tilting very slightly into corners to allow 300km/h running on these lines is now in use to use the line as efficiently as possible while all new Shinkansen are built to run at 360km/h for standard rail lines and 500km/h (310mph) for the new maglev Chuo Shinkansen between Tokyo and Osaka.
LesF
25 Mar 2014
Coventry
Thanks NotATrainspott for that info. Has anyone thought of increasing the speed capability of a turnout by curving both legs in opposite directions rather than having one straight and one curved? For a given crossing angle (I believe an angle of 1 in 65 is proposed by HS2) the track radius can be increased. Furthermore, superelevation of the outer rail above the inner rail can be provided on both legs at the crossing, helping the train to negotiate the curve. Of course, trains would have to slow down on both curved legs, but they would all slow to the same speed rather than just those going onto one branch.
NotATrainspott
2 Feb 2013
Well then you would need to slow down trains that don't need that junction to be there at all, which isn't ideal. There would be no real use in increasing the speeds for diverging junctions as then a wider curve radius would be needed and the entire junction would cost significantly more. The only junction where there might be an improvement would be where the eastern arm joins on north of Birmingham Interchange but even then, the journey time increase for that section is marginal.
LesF
25 Mar 2014
Coventry
At 18tph, all trains will have to slow down if any of them do because they will be so close together (apart from minor flexibility in the headway). So isn't it better to slow them to the speed of the largest radius possible? It applies also at WM interchange where stopping trains will turn out some way before the station so they can stop there while others presumably overtake them. But with a 3 minute headway that means the stop will add at least 6 mins to the journey time.
NotATrainspott
2 Feb 2013
Here's an interesting technical paper on the possible capacity at Birmingham Interchange. This suggests that 18tph will be more than achievable even with some trains taking the junctions to Birmingham and Leeds. In any case, the simplicity of HS2 means that it is easy to timetable captive services as they interact with no other services but themselves and classic-compatible ones. The paper discusses the possibility that with further enhanced acceleration and service braking, it might be possible to run several more trains per hour on this section, although this would likely require captive running to Newcastle, Liverpool and Scotland.
If the junctions where stopping trains leave and rejoin the through line are fast enough, they will not increase the stopping penalty which is likely to be around the 6min mark (including dwell time) at HS2 speeds anyway. The paper linked by NotaTrainspott demonstrates that the minimum headway is still attainable with a 225km/h junction which is assumed to be the fastest available.
The layout of HS2-2 and now HS3 will be crucial, as a diverging junction can only have one VHS leg, the other is limited to a paltry 230kmh.
