quantinghome
- Joined
- 1 Jun 2013
- Messages
- 2,861
This surprisingly informative piece in NCE about the number of platforms needed at Euston is the best explanation I've seen in print to date:
Explained: Why 11 platforms are needed at HS2's Euston terminus | New Civil Engineer
I've a few questions and thought I'd bring them here given the number of forum members who have far more knowledge about railway planning than I do. Forgive my ignorance, some of these questions may be dumb:
1. Is the assumption of a fixed, standard turnaround time compatible with the indicative service pattern, which has a mix of 400m, 2 x 200m and 200m trains?
2. Why is a 30-minute turnaround set in stone? Brand new stations and trains should be able to work quicker than this, even allowing for some minor delays. Do litter clearance between OOC and Euston; seat booking should be automated (why would you even need to have an on-train reservation system anyway? It's likely to be a reserved seat only operation and reservations will be shown on tickets); the HS2-only services are effectively long distance shuttles and may not need catering, or they can restock at the 'country end'. The Euston operation should be: train arrives > passengers off > passengers on > train departs. A quicker standard turnaround will then free up more platforms for any more heavily delayed services.
3. Can the 200m trains be flighted, allowing them to share a platform?
4. If the additional platform at Euston is going to cost billions extra, wouldn't that be better spent upgrading the classic network to make it more resilient so you don't import delay onto HS2 in the first place?
The logic behind that is simple enough – trains are to take turnrounds of 25 minutes so, with 5 minutes “Run out, run in” time between trains, the 18 trains per hour for which the railway is designed (albeit the business case nominates 17 paths per hour for use with the 18th for future growth) needs nine platforms. But 25 minutes is not adequate for the longest distance trains, from Glasgow and Edinburgh, so these ‘step down’ at Euston and are given 25 minutes plus a service interval – a total of 55 minutes. That adds a platform. Then have one more platform, so as not to be working the station to 100% of its capacity, 18 trains per hour, 18 hours a day. Total number of platform = 11.
OK, let’s challenge that.
Q: Why 25 minutes?
A: Trains might be turned round in as little as 15 minutes, but the extra 10 minutes absorb small delays in arrivals. While a very high level of reliability can be expected from the Curzon Street shuttles, Manchester and Leeds train will be mixing it with NPR, and about half the specified service actually originates on the conventional network - as it should, the ability to run trains beyond the new infrastructure is a strength.
Q: Different trains could have different turnrounds, then?
A: No. To operate a terminus intensively, what matters is standardising turnrounds, with a platform occupation chart showing trains fitting together like atoms in a crystal and, crucially, allocating platforms so that when arrivals and departures of different trains coincide, they are made “in parallel” instead of conflicting. ‘Mix and match’ turnrounds make the chart more like atoms in a gas, with a few trains using a lot of platforms.
Q: Isn’t 55 minutes still excessive for the Glasgow/Edinburgh trains?
A: Yes, in isolation. But ‘25 minutes plus service interval’ preserves that crucial pattern of parallel moves in the Euston throat. Besides, due to limited platform capacity at Glasgow they’ll be taking 25-minute turnrounds there, and a bit extra at one end makes up for a deficiency at the other.
Q: But you can plan the service onto 10 platforms?
A: Agreed, but that is just a plan! On (pre-Covid) punctuality, you would expect a train to turn up more than 10 minutes late, on average, hourly. The 25-minute turnround could absorb up to 10 minutes, so the late arrival doesn’t turn into a late start. But above 10 minutes, it will start back late, which delays the next arrival, and within not many minutes the queue of arriving trains is back at Old Oak Common. And this is where the 11th platform comes in. Any train arriving much more than 10 minutes late can be pointed there instead, and all other trains run as planned.
Clearly if two trains in quick succession turn up more than 10 minutes late, the second has a problem, and here the more drastic option of terminating short at Old Oak Common and restarting from there comes into play. That is possible, but no easy matter – passengers have to be forwarded either by Crossrail which isn’t too good for those with heavy luggage, or on the next HS2 to Euston, which plays havoc with the dwell time. Unless the train crew are working back on the same set, their diagrams and breaks will be disrupted. And passengers for the departure have to be shipped to Old Oak, which means anyone turning up at Euston less than about 6 minutes before time will probably miss it.
And the point is this – without the 11th platform, when a train presents more than 10 minutes late, the choice is either knock-on delay at Euston, or terminating it at Old Oak. That’s not the only ‘event’ it protects against, of course – think of the number of ways of blocking a platform with which we are all familiar, such as technical failure of track or train, passenger taken ill on a train, waiting incoming train crew etc.
You don’t need ‘extensive modelling’ to see that running on 10 platforms with the same robustness as 11 means cutting the service. Plausibly, 16 trains per hour instead of 18 would do it, by freeing one of the 10 platforms for ‘events’. Even 17 trains per hour doesn’t do that, it just leaves one platform half-used, and unless the late arrival precisely fits the unused half, that’s no good.
Shorter turnrounds? All that means is that trains turning up less than 10 minutes late, which will happen far more often, become a problem as well. The shorter the turnrounds, the more contingency platforms you need.
Run trains on time in the first place? Well yes. So why aren’t we doing it now? And it’ll cost you, as part of the solution would be infrastructure, such as on critical mixed-use sections like Crewe – Carlisle – Scotland and York – Newcastle. To make termination at Old Oak no more frequent than daily, punctuality would need to be 99% ‘within 10 minutes’.
Add a platform at Glasgow Central so the long turnround can be there, not Euston? OK, let’s see your scheme, at a station built on a viaduct and bounded by a river bridge.
Technology? Advanced signalling such as ETCS Level 3 has benefits on plain line at full speed, and makes the proposed 18 trains per hour at 360 kph even more secure. But it offers nothing at junctions and stations. Traffic Management Systems now emerging can replan a service at short notice, but only with platforms to replan it into.
In essence, how many platforms you need depends on how often, having spent tens of billions on a new railway, you think it is acceptable to tip its passengers out in Zone 2 at short notice. The 11-platform scheme for Euston, developed over years, is a pragmatic balance between cost and the realities of running a reliable train service.
