HS2 construction updates
A good few paths in for material by rail and spoil if you do a search in RTT. New Bilton, Rugby Up Side, Appleford, Oxford Banbury Road etc
Roast Veg
28 Oct 2016
How have the spoil contracts ended up distributed in terms of FOC? I know GBRf were clamoring for as much as possible.
Where to?
Various places. There’s a lot of spoil, coming from lots of sites, so it can’t all go the same way.
Well there's the mine-standard narrow gauge railway that has supported the TBM operation for a start!
Some tunnel drives don’t need a logistics railway - it can all be done by conveyor. I don’t know the proposals for the HS2 tunnels.
18 Oct 2017
Press release from HS2 regarding demolition of western ramp at Euston. Includes link to a timelapse video of the works.
Also found some video shot from one of the tower cranes at Euston:
jyte
27 Oct 2016
in me shed
Presumably similar to the HS1 stuff then as well? There might be some maintenance elements shared between the two, then?
civ-eng-jim
16 Jul 2011
Might be a bit more robust than HS1 which is "only" a 300kph railway. HS2 will be 360kph.
Domh245
6 Apr 2013
nowhere
I thought that the use of the SNCF system had been confirmed for a while now? I certainly recall previous stories about SNCF and HS2 specifically about the OCS
Makes sense to use a proven system - and 300m quid for 589 track km is a bargain! (I must be missing something?)
The thing to remember here is that they're putting the OCS up above a building site, rather than an active railway - making it an awful lot quicker and simpler! No short shifts in the dead of night or expensive weekend possessions, and no need for specialist safety training to get on to the worksite other than what you'd expect for a generic work-at-height building site.
Tobbes
12 Aug 2012
Which is why I can't understand not electrifying EWR at the time of construction, but that's another argument.
And, more importantly, no bridges to raise, track to drop, signalling to immunise, platform buildings / furniture to amend etc. And it’s almost entirely plain line; not that much in the way of complex junctions.
Also, I suspect that this is literally the cost of the OLE, ie not the power supplies or distribution.
Pete_uk
28 Jan 2017
Stroud, Glos
So, no bespoke, overly expensive new OHLE?
I think we need a lockdown to stop the spread of 'common sense'!
BTW how fast is HS1 in MPH?
route101
16 May 2010
Didnt realise the first part of HS1 was that fast , thought it was like under 100 till ebbsfleet or something.
Roast Veg
28 Oct 2016
From the above article:
The catenary will use a design licensed from French infrastructure manager SNCF Réseau, whose V360 OCS is the only OLE design certified under European Technical Specifications for Interoperability for 360 km/h operation.
I would have thought that made it pretty much a sure thing!
Geeves
6 Jan 2009
Rochdale
There was a thread a few years back and the general consensus was that its 140 in the London tunnels when it drops (obviously) for the approach to St Pancras.
Sorry should read up as Liam had already replied! It sure feels faster than 140 leaving London.
It’s not often more than 125mph on a javelin on that section.
miami
3 Oct 2015
Now that construction is underway it would be extraordinary for phase 1 to be stopped.
Oppoisition to Phase 2b will fade over the next few years as it will be a smaller scheme, and fewer people will be affected. Once the diggers have done the bulk of the work through the Chilterns and Staffordshire (2026?) all that will be left are the protests from the east side of the pennines. If phase 2B isn't underway it might be cancelled post 2025 election, but phase 1 and 2a are likely to be fine.
Is there a good site with the construction timeline - what starts when, what work is being done when, etc?
Has phase 2a notice to proceed been issued yet?
Starmill
18 May 2012
Bolton
As noted by The Davibob, although there has been plenty of time put into it I don't think there will be much progress with the High Speed Rail (West Midlands - Crewe) bill for a while yet. Once it receives Royal Assent that's only consent to build the line in place though. I don't know what they plan to do but I'd guess a Full Business Case will be published. Perhaps they will simply update the one published for Phase 1.
I don't think that the next High Speed Rail bill will be deposited for a while either.
18 Oct 2017
They are still hoping to get the Phase 2A Bill though Parliament by the end of 2020. There are only 35 petitions of the Bill for the Lords to consider and some of them have been settled already, withdrawn or not selected. The original Lords programme from March 2020 had them hearing all petitions over a timescale of about two weeks. After that, there's a day or so for Opposition amendments to be considered, a "Special Report" to be written, and the remaining Parliamentary stages of Report, Third Reading and Royal Assent which usually don't take much more than a few days, albeit spread over a few weeks. If I remember correctly, the Lords' Second Reading debate didn't even go to a division (vote) and was thusly passed unanimously, therefore one one expects the remaining Lords votes to be something of a formality.
A newsletter published on the Staffs and Cheshire HS2 "Commonplace" web sites has some commentary on what's upcoming for Phase 2A in the second half of 2020...
18 Oct 2017
Whilst I'm here, I happened across a "photo diary" of HS2 works on The Chiltern Society's web site. I'll link the "front door" below, but it's divided into various locations, just click into each thumbnail and there's a batch of photos behind each one, including (at time of posting) some aerial views of construction sites and plenty of ground level shots of "digger action." I'll resist posting any directly as there's dozens if not hundreds of them to peruse at time of posting (and they are not my images.) Enjoy.
si404
28 Dec 2012
On Friday I went for a walk around Amersham
There's a linear work along the valley to the south of the town - almost like they are going to tunnel cut-and-cover a couple of hundred metres north of the actual line.
But those tunnel linings are a little small! :p
That's because this is a water pipe, not a railway! It's to protect against the risks of tunnelling, with Amersham's pumping station enhanced and Chalfont St Giles' water sent up to Amersham to be treated and then sent back as its pumping station hasn't got room for the upgrade. It's sort of HS2-related, but is rather tangential to the actual scheme (it's almost certainly something that has helped the HS2 budget balloon). However these works are being called HS2 works by locals.
I wouldn't be surprised if, in a couple of years, a very similar long worksite in a similar place is done for the 'Misbourne Greenway' (part of the HS2 cycle route), but there's not been any joined up thinking.
Anyway, the other HS2 prep-works in the town are around the shaft site - improving a road junction next to it to allow HGVs to access it better. These works having been going on and off (mostly off) for over a year now. Actual works on the shaft began on the 4th (when this road closure was to be over - but they are making hay while the virus keeps traffic down and keeping it closed until the end of September, giving them space to do some more work), but there wasn't any evidence of a start on the shaft.
And it's nearly done - presumably the lights will only go red when something wants to turn right (onto the main road - only cycles would be allowed to turn off it heading towards the roundabout, even though buses go and do a u-turn at the roundabout).
Just this filter lane allowing direct access from the A413 to build (though one existed beforehand!) and this bit of the works is done.
