How will Heathrow Crossrail prices be enforced
Harshil
17 Jan 2018
Hi it's common news how using Crossrail to get to Heathrow is going to be priced similarly to the current connect service which is more expensive than the Piccadilly line due to the airport charging a premium for using their tunnels.
How will TFL correctly charge someone who gets on in zone 1 using an oyster card? How will they know if the Crossrail or Picc line was used?
Will there be different barriers on the Heathrow end?
Nick66
19 Jan 2018
I think they are totally different stations, so won’t be too difficult
Kite159
27 Jan 2014
West of Andover
The only terminal where the platforms are close together is terminal 5, both Terminal 4 & Terminals 2/3 there is a moderate walk between the "HEX" platforms & LU platforms. Even with Terminal 5 you need to exit the LU barriers and go up and over to reach the "HEX" platforms.
In terms of the back-end system, it will be like other stations with separate gate lines
Clip
28 Jun 2010
Same way they enforce other higher fares i would imagine
DPQ
4 Feb 2017
This will be similar to how Oyster calculates Gatwick Express fares. If the user goes through the Gateline at Victoria Platform 13/14 they are charged more than if they go through the Gatelines on Platforms 15-19.
Joe Paxton
12 Jan 2017
Though possibly not the best analogy, as Heathrow Express will start accepting Oyster and contactless for fares in the near future (September I believe) so it could lead to some confusion.
Instead I suggest Richmond to Waterloo - both NR and LU passengers pass through the same gates at Richmond, but at Waterloo NR passengers pass through the NR gates onto the main concourse, and LU passengers pass through the LU gates in one of the LU booking halls. They are thus charged the NR or LU rate as appropriate. (Same analogy works for Wimbledon-Waterloo.)
Joe Paxton
12 Jan 2017
Yes. Simple as that!
We discussed this in an earlier thread and the presumption was that differential charging for HEx will be ascertained by a separate gateline at the Paddington end, which AIUI is basically how use of GatEx is decided at Victoria.
Haywain
3 Feb 2013
That deals with the Heathrow Express bit, but the question was about distinguishing between the other two options.
I was only trying to answer the point made above me by Joe Paxton, about Heathrow Express possibly causing confusion. The other two had already been answered earlier.
Joe Paxton
12 Jan 2017
Yes, I know, and that makes sense.
I was merely suggesting that an analogy that compares the difference between the Piccadilly line and Crossrail (for journeys to Heathrow) to the difference between Gatwick Express and Southern (for journeys to Gatwick) isn't ideal, as it might confuse people when Heathrow Express soon gets added to the mix!
Yes, I know, and that makes sense. I was merely saying that an analogy that compares the difference between the Piccadilly line and Crossrail to the difference between Gatwick Express and Sourthern might get confusing when the Heathrow Express later gets added to the mix!
See what you mean now.
Joe Paxton
12 Jan 2017
I can't think of any suitable analogy really for a situation where there will be three different Oyster/contactless fares for journeys between two points in Greater London / the PAYG area. (I'm just thinking about rail transport here, not buses.)
bnm
12 Oct 2009
Whilst the single fares using TfL Rail (Elizabeth Line in the future) to Heathrow are more expensive than the Piccadilly Line, the Daily Cap on Oyster is the same as Zones 1-6. Heathrow TfL Rail Stations are now shown on maps as being in Zone 6. Zones 1-6 Paper Travelcards are also now valid to Heathrow on TfL Rail services.
Oh, and Crossrail isn't being used as a name for the line or its passenger services.
Haywain
3 Feb 2013
From an Oyster perspective it's not 2 different points though. There are (or will be) 3 separate gatelines at Paddington so it will be easy to distinguish which route has been taken and charge accordingly.
Mag_seven
1 Sep 2014
here to eternity
I wouldn't try to travel to Heathrow on Heathrow Express using Oyster PAYG or a paper travel card anyway as HEX have rigorous on board checks.
Haywain
3 Feb 2013
They will be accepting PAYG from September, but not paper Travelcards. The "rigorous on board checks" will uncover incorrect use of either both before and after the September change.
Joe Paxton
12 Jan 2017
Yes I appreciate that - I was really thinking about it from perspective of a curious (prospective) passenger who isn't au fait with the underlying mechanics of the Oyster/contactless system - i.e. the perspective of the OP of this thread!
Haywain
3 Feb 2013
Indeed, and the answer is that they will know which route was used by knowing which gatelines were passed through.
Joe Paxton
12 Jan 2017
Just like Gatwick Express
Agreed - my point above regarding the analogy was simply that comparing Crossrail to the Gatwick Express, where the Piccadilly line equates to a Southern train, is likely to cause confusion once Heathrow Express itself starts accepting Oyster/contactless in September, that's all!
I absolutely accept that GatEx (at Victoria platforms 13 & 14) demonstrates the principle of how different gatelines can provide for different fares.
I think we're all in vehement agreement with each other!
danthekyle
16 Aug 2017
That's a great trivia question. On paper, I believe Abbey Wood - Farringdon will have three different Oyster fares when Crossrail opens in December (peak fares shown):
Direct on Crossrail: £3.90
Direct on Thameslink: £4.10
Using Southeastern/TL then DLR and/or Tube £5.80
In reality though I don't think the system won't be able to differentiate between these routes well, because the gatelines at Abbey Wood and Farringdon aren't segregated. Obviously you'd be charged the higher tube fare if you changed to the tube at London Bridge, but I don't think you would if you changed at Woolwich Arsenal for the DLR.
Haywain
3 Feb 2013
As Oyster is clearly incapable of dealing with TOC specific fares if they share gatelines, I can't imagine they will be more than one Oyster PAYG fare for the journey regardless of route.
MikeWh
15 Jun 2010
Crayford
There will be two fares. Default will be £3.90, Alternative will be £5.80 when changing to Underground at London Bridge, Blackfriars etc.
paddington
19 Feb 2013
West Brompton to Highbury and Islington ought to be £2.90 peak / £2.40 off-peak if going by tube through Zone 1, but only the £1.70 peak / £1.50 off-peak fare exists.
adrock1976
10 Dec 2013
A hypothetical scenario here, but how would a Highbury & Islington - Heathrow Rail work with Oyster or contactless?
There are various routes that could be used such as:
Victoria Line to Oxford Circus, Central Line to Ealing Broadway, then London Crossrail
Overground to Stratford, then either Crossrail direct or Central Line to Ealing Broadway, then Crossrail
Overground to Willesden Junction, then Bakerloo Line to Paddington, then Crossrail or the Express
Overground to West Brompton or Kensington Olympia, District Line to Earl's Court, District to Ealing Broadway, then Crossrail
Overground to West Brompton or Kensington Olympia, District Line to Earl's Court, Piccadilly Line to Heathrow
Northern City Line to Moorgate, then Crossrail direct
There may be other variations for this journey.
danthekyle
16 Aug 2017
Yes, I agree it will be quite simple in practice, but if you were to look at the fares tables, there are three scenarios that could apply in theory (TfL-LU, NR1, NR1-T).
Are there many other examples (excluding airports) where two direct services between the same two stations are notionally supposed to charge different PAYG fares? Most of the other rail routes I can think of charge the Tfl-LU fare where they run the same routes as TfL services.
DY444
16 Sep 2012
Not sure if this counts but I have an idea that London Bridge (NR) to Waterloo E is more than London Bridge (LU) to Waterloo (LU)
MikeWh
15 Jun 2010
Crayford
London Bridge (NR) to Waterloo East is £2.70 peak, £2.20 off-peak.
London Bridge (LU) to Waterloo (LU) is £2.40 at any time.
