Is there a way on how to get to the abandoned British steel Redcar station.
I know there’s no stopping services but I don’t know if there’s a nearby footpath either if anyone knows cheers
Right perfect thanksCompletely inaccessible now to members of the public. There are no footpaths that lead to or from it that are publicly accessible and anyone attempting to reach the station would be trespassing on private property and whilst there's likely no real legal jeopardy to this (assuming you don't damage anything) you are very likely to be escorted off site by security guards (who do patrol the site regularly). I'm not sure if the railway would try and get you under the Byelaws for criminal trespass if you did make it to the station but it seems unlikely. If a driver spotted you though they'd likely phone it into the signaller that someone was trespassing so that might may well cause some disruption to services.
Even when the station was open it was only possible to visit by train and you were not permitted to leave the station as, again, there was no public access. When I did it a security pick-up truck drove past a few times whilst I was waiting for my train out of the station and I very much got the vibe they were keeping tabs on me. I believe it was not unheard of for security to actually be waiting at the station to make sure any visitors didn't leave the station grounds.
Reality is that there is no way to visit the station other than the brief sight of it as you pass through non-stop on Northern or TPE.
Is the nearest you could now legitimately get to, perhaps a few hundred yards away from the closed station, maybe somewhere along the Teesdale Way, near the big roundabout on the A1085 Trunk Road?Completely inaccessible now to members of the public. There are no footpaths that lead to or from it that are publicly accessible...
Yep that's correct that's about as close as you can get these days but there's no view to be had as the ex-hot metal railway (the link from the blast furnace to the steel mill where torpedoes of molton iron used to run along) is on an embankment so blocks the station from the Trunk Road.Is the nearest you could now legitimately get to, perhaps a few hundred yards away from the closed station, maybe somewhere along the Teesdale Way, near the big roundabout on the A1085 Trunk Road?
Depends how much you'd like to try and debate a security officer regarding public rights of way.Is the nearest you could now legitimately get to, perhaps a few hundred yards away from the closed station, maybe somewhere along the Teesdale Way, near the big roundabout on the A1085 Trunk Road?
The dashed blue line to the east may be a public right of way, which at first glance (I haven't measured with aerial footage) may be ever so slightly closer than the road at the knee.
There are two (massive) caveats though:
The first is that it hasn't been recorded on a 'definitive map', which is what cartographers will use when producing maps of rights of way, so it may not so on OS maps for example, even though it may be a public right of way. The Ramblers have a campaign around this called Don't Lose Your Way, where they're trying to get historical public rights of way retained, in the face of the government trying to abolish them simply because they weren't added to a definitive map. In any case, if you meet a landowner when trying to use a public right of way not marked on an OS map, which the landowner will often have, it probably won't be very amicable.
The second is that it may be an abolished public right of way. Some consultation with the local authority would be in order. Though if you look at aerial footage of where this potential PRoW is, it does appear that there is a well used crossing point on the A road which continues to the south, suggesting at least part of it may still be in use.
Of course from the A road, the potential PRoW appears inaccessible to the north which means you probably won't even get to the point of seeing a security guard to discuss the history of public rights of way
In short - practically speaking, the roundabout is probably the closest; but if you fancy finding a way to the potential PRoW to the east, and a protracted discussion with an underpaid security guard about the Wildlife and Countryside Act 1981, you may be able to get very marginally closer.
Additionally, unless the intent is specifically to get pictures of the abandoned station (although there are seemingly plans to redevelopp the area eventually, so if you have a few or several years of patience available...), you'll probably be able to get much better shots from the other stations on the line, for much less of the hassle.In short - practically speaking, the roundabout is probably the closest; but if you fancy finding a way to the potential PRoW to the east, and a protracted discussion with an underpaid security guard about the Wildlife and Countryside Act 1981, you may be able to get very marginally closer.
Doesn't look like any right of way to me. Which begs the question. What is the blue line? Some sort of land ownership boundary?The dashed blue line to the east may be a public right of way, which at first glance (I haven't measured with aerial footage) may be ever so slightly closer than the road at the knee.
It's a potential right of way which is (was, threat gone for now) at risk of being lost. Might have some luck convincing the LA to add the southern part of it to the definitive map, but not so much the north part on the private land now!Doesn't look like any right of way to me. Which begs the question. What is the blue line? Some sort of land ownership boundary?
You may well be right, but it does just look as if someone has been busy with a blue crayon. Can't make out any likely tracks when looking at a satellite view of the area. Which, of course, doesn't get you any nearer to the now closed station, unless you're passing by (non-stop) on a Middlesbrough->Saltburn train, or maybe flying a camera/drone (if that's actually allowed).It's a potential right of way...
Blue just means nobody from the Ramblers has reviewed it. Other colours exist for other priorities. It is overlayed on an OS map so I think it was meant to stand out a bit from normal map features:You may well be right, but it does just look as if someone has been busy with a blue crayon.
I don't know how you could find your way onto a path that doesn't exist!Of course nobody is actually going to propose trying to retain this as a public right of way, but be interesting if you could find a way onto it![]()
Nobody said it would necessarily have been a recent right of way. The common law concept of rights of way goes back centuries. Statute law some 1940something after the war.There's nothing there to be a right of way to have been lost! That blue line leads from the Trunk Road into a drainage ditch (with no bridge, no indication of there ever having been a bridge), across the remains of Steel House's car park (which has been there since the 1970s), to a railway line with means of crossing (a railway line which has also been there since the 1970s).
I don't know where the Ramblers got the idea for there having been a right way of way there but if there was one it hasn't been there for fifty years!
Right of way does not necessarily mean pathI don't know how you could find your way onto a path that doesn't exist!![]()
Sure, but for someone who wants to view the station (even if they're willing to have the relevant arguments assuming it is legitimately a right of way) it's not much good if they've got to ford a drainage ditch, bush-whack through an overgrown car park edge and then potentially illegally cross a railway lineNobody said it would necessarily have been a recent right of way. The common law concept of rights of way goes back centuries. Statute law some 1940something after the war.
There are many rights of way which no longer have a physical presence. Many in Snowdonia for example which are just green lines on the side of a hill on an OS map, but nobody is a really walking them to maintain a visible path.
Depends how adventurous you're feeling and how desperate for that station photo!Sure, but for someone who wants to view the station (even if they're willing to have the relevant arguments assuming it is legitimately a right of way) it's not much good if they've got to ford a drainage ditch, bush-whack through an overgrown car park edge and then potentially illegally cross a railway line![]()
More likely it's just a very old right of way. There's absolutely tons of them which are so old it would be hard to imagine the landscape supporting them. There's one which goes right through the buildings and treatment facility at Mogden sewage works for example.Honestly I reckon someone at Ramblers has simply been on the sauce a bit too much one night and drawn that on by accident.
Hmm I suppose, though it's neither use nor ornament now 120+ years later! I'm all in favour or protecting useful rights of way but this is clearly one that can be happily left to be de jure deceased to go with it's status as being de facto deceased. For the OP and anyone else it's utterly useless (and inaccessible).More likely it's just a very old right of way. There's absolutely tons of them which are so old it would be hard to imagine the landscape supporting them. There's one which goes right through the buildings and treatment facility at Mogden sewage works for example.
I took the coordinates of the bend of the blue line and pinned it on a map from 1902-1905 and it looks like it used to be a road/track:
And if you look at the current roads, you can see where it would've connected to the current road on the north end, which carries on going east.
