Hi, does anyone know and could tell me how to measure curve radius? I would like to compare the sharpness of curves (Rutherglen, Earlestown, Shipley, St Pancras LL) for example to see which one is the sharpest. Thank you!
That does need quite a large map (or screen) though.Are you assuming that the curves are of a constant radius - which is unlikely but probably a necessary assumption. That is a curve made from Hornby 00 track will be of a constant radius -but not probable in real life.
Then you have to identify where the curve starts and ends.
Then within the bit of interest draw 2 tangents - and then where each tangent 'grazes' the curve draw the perpendicular (that is a line at right angles).
Where the 2 intersect is the focus of the curve - and the distance from the focus back to the curve is then the radius you are looking for.
But since you cannot go to the railway and start making measurements - it'll have to be done from a large scale map - Open Street Map will be better than Ordnance Survey because it is a vector map (OS is a raster map) and so can be zoomed on line to fill your computer screen .
Yes, looks right to me, and rather simpler than the calculations I remembered, which got into heavyweight trigonometry. Maybe I was calculating something else then!for your method - if r is the radius, l is the length of the chord and a is the offset - then good old Pythagoras tells us that after simplification that
r=a/2+l*l/(8a)
just check my workings though - done quickly on 'the back of a fag packet'
It would have made a good GCE O level question - esp if it asked for 2 ways of solving the problem - your way and my way
I place cylindrical objects on my laptop screen and compare the curves, making sure I have the same scale on both maps.Hi, does anyone know and could tell me how to measure curve radius? I would like to compare the sharpness of curves (Rutherglen, Earlestown, Shipley, St Pancras LL) for example to see which one is the sharpest. Thank you!
Particularly as you can do it just on a section in the 'middle', where the curve is probably at its sharpest.This is why railways measure things in chains. You attach one end of the chain to the outer rail of the curve. You attach the other end of the chain to the outer rail. You then measure the sideways distance from the rail to the midpoint of the chain. One of they clever formulae (or a table) above gives the radius of curvature, from the sideways distance.
Better still, draw 3 tangents, roughly equally spaced. If the 3 perpendiculars intersect at a point, great. If they make a small triangle, eyeball the centre of that. If they make a large triangle, you need to try harder (or the constant radius assumption is too far from reality).Are you assuming that the curves are of a constant radius - which is unlikely but probably a necessary assumption. That is a curve made from Hornby 00 track will be of a constant radius -but not probable in real life.
Thanks for the information, I knew curves were measured in chains but had no idea howThis is why railways measure things in chains. You attach one end of the chain to the outer rail of the curve. You attach the other end of the chain to the outer rail. You then measure the sideways distance from the rail to the midpoint of the chain. One of they clever formulae (or a table) above gives the radius of curvature, from the sideways distance.
pwayblog.com
