Forgive the newbie question, but how is it possible to 'lock-up' (ie overcharge) carriage air brakes? I've heard stories of exasperated freight drivers having to walk the entire length of their train to release air from the brake cylinders of every carriage.
From what I understand of air brakes - admittedly not a whole lot - the brake pipe won't go higher than 500 kPa. I know that with the No 4 W valve, which runs air straight from the main reservoir to the locomotive brakes, it's possible to end up with over 500 kPa in the locomotive brake cylinders. But how is this possible with brake pipe air running via an equalising reservoir? What is the unfortunate combination of applications with a 26L that could leave you with overcharged brake cylinders?
Many thanks for any information.
