- Joined
- 14 Jul 2011
- Messages
- 20,376
I'm a little confused by this statement.Once HS2 is done there will only be the Connect trains and a GA style semi-intercity service to Nottingham. You'll still need to run relatively fast trains to Leicester and putting 2 more tph on Birmingham-Derby will make the upgrade even more expensive given it will require ever more expensive infrastructure interventions.
As it stands, HS2 will do nothing for the MML.
However, if a connection from HS2 to the Birmingham-Derby line is built, it may be possible to get traffic out of St Pancras and into a hopefully higher capacity HS2 core.
In that situation, only a vestigial service to Leicester or Nottingham would remain in St Pancras alongside the Corby EMU.
EDIT:
I make the distance required to connect the stub for the Eastern leg to the line through Tamworth at about 2.5km of additional route.
