How to go about getting the Class 483 to work on any route?
bengley
18 May 2008
Hey,
I'd like to use the IOW class 483 on the Paddington route (going to electrify some with third rail). How can I use it on the route? When I use the scenario editor to add a train, the train isn't there, however when I do it on the IOW route, it works.
thanks.
jp4712
1 May 2009
Lichfield
You need to click on the Object Set Filter (on the left hand flyout, it's a blue cube with a little orange triangle on it) and then in the top right flyout that appears, select the provider of the train. I'm not sure if you're after the 38 stock that comes with the IOW route, but if you are search for the provider 'RSDL' and then tick the box next to 'Island Line'. If its the Standard stock from Richard Scott from www.uktrainsim.com, then the provider name to look for is RScott.
Hope that helps
Paul
bengley
18 May 2008
Hope that helps
Paul
Ahh! Thanks man. It's one of those things which is just so simple, right in front of you.
:D
