How to deal with MMI question
Kieranmcd
4 Oct 2023
Spoke to head of recruitment with my toc, it does count.
Hi, in a similar situation and wondering the same. Your TOC recruitment is saying you lose a life if you fail at the interview stage?
I currently have 2 lives and an interview coming up. I've never sat psychometric tests but I will if I progress. If I don't pass the interview then I've lost a life?
Cheers
Class2ldn
25 Feb 2011
Any MMI done by toc or opc counts as a life, doesnt matter where in the process it is, its one element of the tests so unless the tests change again its 1 life lost unfortunately.
There are 2 interviews, one is the mmi which forms parts of the psychometrics, the other is the dmi which is the more traditional format of interviewing with a manager, HR etc and doesn't count toward a life lost
A Wild Acorn
10 Jan 2024
Selhurst
Cheers
So the assesments and the MMI are what will cost a life if failed, the DMI is its own internal interview with the company you are applying for. You are only allowed one fail.
Wivenswold
24 Jul 2012
Essex
Best of luck. It's safe to say that "I'd phone my union rep", "Wait for it to blow over" or "take my PNB" are not correct answers to any of the questions.
Kelki
25 Feb 2021
Last year was my 2nd attempt at the DMI where I got the job, same TOC
Twotwo
10 Aug 2018
Congrats, you remember your mmi questions by any chance? I’ve got mine next week been prepping tonnes of scenarios was hoping to try narrow them down.
The questions are actually on here, if you search for MMI it should come up. I've seem to have forgotten but some of the questions are to dealing with rules and procedure and emergency.
A Wild Acorn
10 Jan 2024
Selhurst
Yeah I had a look around and got a general idea however a lot I found were from like 2017-2020 so was tryna find some more recent.
A Wild Acorn
10 Jan 2024
Selhurst
They haven't changed since then
Thank you mate, so I’m assuming it’s these?
1. Describe a time when you followed rules and procedures
2. Describe a time when you have solved a difficult problem
3. Describe a time when you have been on a training course over 2weeks or greatest achievement
4. Describe a time when you have handled an emergency situation
5. Describe a time when you have worked for long periods of time alone
6. Describe a role you do similar to a train driver?
SCDR_WMR
17 Dec 2017
Crewe
If you plan for those you won't be far off. Some are similar/same, some are different to those
Kelki
25 Feb 2021
Sorry no, but they were definitely more exploratory than the DMI in my opinion. The questions are on here somewhere sorry.
ComUtoR
13 Dec 2013
Try to remember that it isn't just about what questions get asked. In a lot of cases, it is more than just about the answer you give.
A Wild Acorn
10 Jan 2024
Selhurst
I am aware of this but this is not what I’m currently trying to find out, I’m trying to find out the questions so I can narrow down my scenarios.
SCDR_WMR
17 Dec 2017
Crewe
In fairness, they do expect you to come up with them in the alloted time given rather than have them already prepared. So don't overthink it.
LCC106
16 Nov 2011
Exactly this. As I was trying to say earlier but lost in translation between brain and mouth. You really have to be the right person for the job, to be able to think and act under pressure. That’s all part of the interview.
A Wild Acorn
10 Jan 2024
Selhurst
Mmmm I see so they’re quite literally just looking for brief scenarios from us that we can then expand on in response to their probing? I’ve put together so many scenarios and expanded on each massively using the star format so hopefully I’m well prepared for the probing. Typically in interview I’m very calm and good on the spot but I’ve not experienced the MMI before so I can only hope it goes well. I don’t usually have things go my way so I’m not counting my chickens.
SCDR_WMR
17 Dec 2017
Crewe
Yes. You will put a number of brief scenarios that you know intimately onto a sheet of paper (have about 20-30 minutes), go for lunch and when you come back you will be called 1 at a time to sit the interview.
They will select which ones to use, I think I was asked 3 or 4 of them both times I've sat it. They will asked you to explain in detail each time and they will probe you on your response. Often interjecting and trying to upset your rhythm. OPC like to ask 'how did that make you feel' constantly, TfW were more relaxed and encouraging in conversation.
I was asked to change my scenario on one as they couldn't probe the answers to give them the required responses, so be prepared for that eventuality.
A Wild Acorn
10 Jan 2024
Selhurst
Thank you. I’m assuming you did this on the assessment day? As I’m going in specifically for just the MMI.
A Wild Acorn
10 Jan 2024
Selhurst
Yes. Both times
Was you successful the 2nd time?
I’ve got my MMI with my specific toc at their HR centre, it’s allowed time for 4.5 hours so feels like it’s going to be torture ahah. I emailed to ask if it’s just the mmi and if it’s just me and they confirmed.
SCDR_WMR
17 Dec 2017
Crewe
I passed MMI both times but wasn't offered a position. 3rd time lucky I hope , though I won't have to resit testing this time.
It might be due to numbers attending as it will be around 90-120 minutes. So if there's say 6 to do and 2 examiners, it will take all afternoon (others may be sitting testing before you arrive also)
A Wild Acorn
10 Jan 2024
Selhurst
They told me it’ll only be me there on the day so lord knows then, I’ll have to update when I’ve done it!
And damn atleast you pass everytime and have experience with it, just a matter of getting the offer next time!
marco sadler
4 Apr 2022
kent
yeah i had similar questions
