How to check valid route for one journey
rubin
23 Mar 2024
bristol
recently I bought a return ticket from Manchester to Bristol and another one from Sheffield to Bristol. The difference is that on the Sheffield one it shows 'Not Valid via London' but no such on Manchester ticket. I know they both seem to be not the valid route but why only showing the alert on the Sheffield one. Does that mean it is 'actually' valid to travel via London using the Manchester ticket. more broadly speaking how can I check the valid route for a ticket.
jfollows
26 Feb 2011
Wilmslow
If it says “any permitted” then it’s valid on any route defined by the routeing guide, not by any route you happen to fancy.
Manchester-Bristol “any permitted” is valid on routes shown by maps
  • MP
  • PM
  • NR+MP
  • NR+PM
at https://rgpp.iblocks.co.uk/maps
which do not include London.
It also happens that Sheffield-Bristol “any permitted” is not valid via London either. However there’s a separate “+VIA CHESTERFIELD” fare available, in which the “+” means including London Underground via London. So the “not via London” fare is to differentiate it from this.
See https://www.brfares.com/!expert?orig=SHF&dest=BRI&period=20260113
Manchester-Bristol has an alternative “via Hereford” ticket, but none “via London”.
EDIT: I was wrong, @AlterEgo is right, Sheffield-Bristol “any permitted” is valid via London. The problem is, there’s no “any permitted” ticket available other than singles priced by LNER. See https://www.brfares.com/!expert?orig=SHF&dest=BRI&period=20260113. The answer to your reasonable question is not simple.
This is a very good site, which isn't faultless, but will help you interpret the Routeing Guide easily (the RG is what determines which routes are permitted).
Manchester to Bristol is not valid via London.
Sheffield to Bristol is valid via London, but only if you have an Any Permitted ticket. As it is, your ticket restricts routes to avoiding London.
rubin
23 Mar 2024
bristol
  • MP
  • PM
  • NR+MP
  • NR+PM
thanks for your detailed explanation. but what is the difference between MP and PM (that is the same route?) and does NR means Manchester Bristol ticket is valid via Warrington?
jfollows
26 Feb 2011
Wilmslow
You need to look it up on the map link I already gave you, https://rgpp.iblocks.co.uk/maps
NR means via Warrington Central and walk to Bank Quay.
EDIT MP is via Shrewsbury, PM is via Birmingham
