How should the Hayes & Harlington bay platform be utilised?
cle
17 Nov 2010
Seems a good space to tease an incremental extension to, of say, 2tph Paddington terminators, in time - if there is demand and paths could work. Maybe speed up an airport pair.
It is entirely reasonable to have infrastructure that is available to keep the service going in perturbation that doesn't need to be used for a timetabled service.
Peregrine 4903
18 Aug 2019
The GWML is full. In fact its likely the amount of service Crossrail want to run on the GWML is already too much for the GWML to deal with.
The GWML is genuinely one of the few routes post covid that will remain full.
Kite159
27 Jan 2014
West of Andover
Keep it spare in the event there is issues towards Heathrow (ie broken down train/fire alarm etc)
Wouldn't be the only bay platform on the network not to see regular booked use.
AviationFR
30 Apr 2022
If the GWML is full then perhaps a new high speed route to say Bristol via certain major stops should be built to alleviate the pressure on the conventional line
cle
17 Nov 2010
I didn't really think this was worthy of its own new thread - but we will have to see how full the GWML becomes with Crossrail, and with everything from Padd extending to OOC in time. There is an absolutist stance on this, but the reliefs are not as full as the mains and we have to see the Crossrail impact and operation. Even now, they are tinkering with stopping patterns.
I would think some peaks extensions onwards from OOC to H&H could be done - new airport frequencies are appearing after all. Perhaps those aren't all needed and get cut back to this bay. Might be useful - that's all really.
mr_jrt
30 May 2011
Brighton
Knock it through and use it as a loop? Doing that would also enable you to link through to the up relief Heathrow flyover line and you could then run shuttles between the platform and Heathrow to connect with the mainline Crossrail services, giving more capacity between Heathrow and the core.
Non Multi
11 Dec 2017
I recall that conversion to a loop was proposed as an idea in the early days of the current XR scheme, but shelved due to cost.
andreading
27 Apr 2019
Turn it into a loop with cross platform interchange between east and west bound for Reading line and Heathrow interchange and save £500m on WRATH.
I concede that new flats are being built at various places between Ealing and West Drayton but the route has never been the busiest for commuting. I doubt that services to Hayes & Harlington bay are needed in the short term. Longer term may be more interesting if the corridor were to see more commuting in the future.
cle
17 Nov 2010
I agree - but it had ****ty 2 car turbos and low frequencies for years.
It is already much busier, and happening with the new apartments all along that corridor coming online, but within months - it will ostensibly on a very fast, roomy tube line - directly through the core of London. I think it will see HUGE change as a corridor. Into London, out from - Heathrow interchange and later, OOC interchange. And tons more development accordingly.
