How Railcards work.
Joseph T
15 Nov 2023
SWR territory
I'm currently considering buying railcards for myself. So far I know that one railcard can grant a 1/3 discount when buying a ticket, but beyond that I don't know much else. Could you answer the following questions for me?
  • Is there a limit to how many railcards you can own at once and/or apply to a ticket?
  • If you apply two railcards to a ticket, do you get 2/3 off or 1/3 off of 1/3 off from the original price?
  • Can you buy a railcard when you already have a valid card of the exact same type?
skyhigh
14 Sep 2014
You can have as many Railcards as you want, as long as you meet the qualifying criteria for the Railcard. You cannot apply more than one Railcard to a ticket.
As above, you can't.
Yes, though I can't think of many reasons why you'd want to.
jfollows
26 Feb 2011
Wilmslow
I have a Two Together railcard for travelling with someone else and a Senior railcard for travelling on my own or when the other railcard can’t be used. All perfectly normal.
Mcr Warrior
8 Jan 2009
[*]If you apply two railcards to a ticket, do you get 2/3 off or 1/3 off of 1/3 off from the original price?
Like your thinking. If you're eligible for three railcards then you get three discounts meaning it's free travel! Say a Network Railcard + 16-25 Railcard + Veterans Railcard? Unfortunately, it doesn't quite work like that!
[*]Can you buy a railcard when you already have a valid card of the exact same type?
This might be useful if wanting to buy a one year 16-25 railcard just before your 26th birthday and you already held a one year 16-25 railcard bought eleven months ago which still has a little bit of (unexpired) validity.
Hadders
27 Apr 2011
Which railcard are you considering buying? Different rules apply to each railcard.
ikcdab
3 Feb 2012
Cogload Junction
i also like your (tongue in cheek) reply. It wouldnt work like that. the second 1/3 discount would be from the discounted price, not the original price. Thus you would need an infinite number of railcards to achieve free travel - and even then it would never be absolutely zero!
pokemonsuper9
20 Dec 2022
Greater Manchester
Although with fares being rounded to nearest 5p, you could eventually get to 0p.
Certain railcards (e.g. 16-17 Saver) give different discounts, the 16-17 gives half price on any (non-ScotRail) ticket.
Joe Paxton
12 Jan 2017
Two Together railcards would be one case, if there are multiple people you frequently travel with.
I've concurrently (co-) held 2 x Two Together Railcards more than once in the past. The savings for just the one trip can sometimes make it worthwhile.
fandroid
9 Nov 2014
Hampshire
But then you can dump the older card as the new one would be immediately valid. In fact it would be highly recommended to put the old one right out of action to ensure that it's never accidentally used after its expiry date.
Edit: small change for clarity
Deafdoggie
29 Sep 2016
I've held a Family & Friends Railcard and a Disabled Railcard simultaneously. Although the children are no longer young enough to benefit from the F&F now, so it's just the Disabled one.
Fawkes Cat
8 May 2017
For completeness, it may be worth adding that all of the Railcards have some sort of condition that has to be met to use them. I think it's right to say that if you are
- aged between 30 and 60 and
- not a student in full time education and
- not disabled and
- not in the armed forces or a veteran and
- travelling by yourself (i.e. without another adult or child) and
- not travelling in the Network South East area and
- not holding an annual season ticket in the Gold Card area and
- not unemployed and authorised to obtain a jobseekers railcard
then you won't be entitled to use any (GB wide) railcard. No doubt there are local railcards which someone otherwise excluded could get - but they're likely only to be of use in their local areas.
Haywain
3 Feb 2013
None of those three entitle the use of a GB-wide railcard either.
Fawkes Cat
8 May 2017
Fair point - a bit of a failure in my logic.
Is that the case for the jobseekers railcard? Never having seen one, my impression was that they did have national validity but it sounds like this is one of many things that I need to learn.
Haywain
3 Feb 2013
Well, I thought it wasn't valid in Scotland but it seems that it is. However, I'm saved from being wrong because it isn't valid on Southeastern High Speed services!
kkong
8 Sep 2008
You can be the spouse, legal partner or dependent child of a person in this category and use an HM Forces railcard when travelling by yourself.
