Nottingham59
Any ETCS experts out there?
I understand that ETCS allows more train paths through complex junctions. I'm trying to understand just how quick the system is.
For example, when train A passes through a junction followed by train B, then I assume the following steps are needed:
Thanks in advance.
(If it helps, the specific situation is trying to understand how many trains per hour could traverse the throat of Old Oak Common acting as a terminus for HS2.)
- ETCS detects that train A has cleared the point of conflict
- The signalling system switches the points (assuming the route has previously been set up by the signaller)
- ETCS detects that the points have switched and proves they are locked
- ETCS issues movement authority to train B
- Train B receives movement authority
- B calculates a revised braking curve and a new maximum speed
- B displays the new data to the driver
- Driver responds (or is the speed controlled automatically?)
Thanks in advance.
