How many turntables remain in use on Network Rail infrastructure?
D1537
11 Jul 2019
North Yorkshire
There's one at York by the depot north of the station.
There is also one at Heaton Depot though I'm unsure if it's still in use.
Northampton
Is the one at Fort William still there? I don't think it sees much use as there isn't one at Mallaig
It sees a reasonable amount of use turning engines to get back to Glasgow.
In addition to York, Scarborough, and Fort William, I think there's one at Aberdeen and might still be one at St Blazey.
Visible on Google Maps are turntables in Heaton (Newcastle) and Neville Hill (Leeds) depots, I don't know if they're still there
Is there still one at Old Oak Common for turning HST power cars?
Long gone by the looks of Google maps, the Crossrail Depot, HS2 and GWML site have swept it all away.
There is also a turntable in Carnforth Steamtown.
Engines can also turn on triangles, and if there's a station that's used regularly by Steam the chances are there's a triangle or turntable fairly nearby.
Sir Felix Pole
21 Oct 2012
Wilmslow
St. Blazey in Cornwall - refurbished recently by MP Kernow. Questions still remain about the whole depot area however, and sadly it looks as if the last train from Par Harbour has run with the dryer about to be switched off.
Technically not NR infrastructure, but Robertsbridge has just acquired a turntable that will be accessible from the mainline, so could become a rail tour turnback point in future. Does have an insane number of reversing points to get to though.
Northampton
How long is the headshunt from NR? On google maps there looks to be stop blocks about 70m from the toe of the crossover. That length would be fine for a visiting loco and support coach, but you won't be getting any tours terminating at Robertsbridge with that length.
The siding does appear to continue for some distance behind the blocks though (full length appears to be c.230m), so maybe one day a full tour could do it.
WestCountry
31 Dec 2010
Cambridge, UK
The headshunt was relaid and reopened to its full length last year, following some quite extensive work to stabilize the embankment. It's already been used by at least one railtour.
Only moves the problem along though - now the length of the bay platform is a constraint.
rower40
1 Jan 2008
There is provision for turning vehicles using the West Ealing/Hanwell/Drayton Green triangle. This allowed the Old Oak Common turntable to be taken out of use in the mid 1990’s.
Northampton
Oh interesting. Thanks for the update.
D6130
12 Jan 2021
West Yorkshire/Tuscany
Yes....but that's a long way to drive an HST power car in reverse! ;)
19Gnasher69
1 Jul 2021
Aire Valley
The Railway Heritage Register On-line has a turntable survey section.
It includes national rail and heritage railway turntables.
I assume that it’s exhaustive but can’t claim to be an expert.
marshlinker
18 May 2026
Romney Marsh
Google Maps is now out of date and the Network Rail Siding was repaired last year. This is a link to the RVR Blog on the NR works which used the RVR yard for access:
https://rvrailway.blogspot.com/2025/10/network-rail-headshunt-ballasting-and.html
The limitation is now the distance between the "bay" blocks and the point to the RVR. A five car Hastings Unit ran through in April on a private special. It's featured in the recent Green Signals Video.
Magrar
20 Jun 2026
Reading
Never mind turntables, what about traversers?
My tiny mind was truly blown when I realised they were a thing.
D1537
11 Jul 2019
North Yorkshire
Apart from the ones in works facilities, there is one at Felixstowe North terminal and one at the Daventry International Freight Terminal.
Both are used to move locomotives across tracks to save having to have a run round facility. I'm sure there are others as well.
RGM654
19 Jul 2022
Harrow
It seems more common to run along the branch and turn on the Greenford triangle.
