Elecman
No but would be possible. But certainly open to confusion for booking ticketsAre there still trains which stop at both?
I believe local pronunciation of Cowden is Cow-den, with the emphasis on the den.Cowden often called Cowden (Kent), on tickets at least - why? I can only think of Cooden Beach (Sussex) or Cowdenbeath, hardly likely to cause confusion surely.
There is a small place called Swindon somewhere I believe, possibly Gloucestershire? Doesn't have a station though.
I seem to recall that locals in Fife pronounce it Coo-denbeath !
As well as minimising confusion with asking for tickets, the 'explanation' part of the name helps to prevent (or minimise!) the ability to adjust the name (fraudulently). Many stations only one letter changed to look like another.Cowden often called Cowden (Kent), on tickets at least - why? I can only think of Cooden Beach (Sussex) or Cowdenbeath, hardly likely to cause confusion surely.
There is Swindon Village in the outskirts of Cheltenham, but I suspect the two Swinton stations in the North are the reason for the "Wilts"You could also have Rye to Leigh via Wye, which would be possible but would involve a loop round East Kent.
I believe that is the case, I remember East Croydon announcements in the 80s pronouncing it as such.I believe local pronunciation of Cowden is Cow-den, with the emphasis on the den.
The same applies to Horsmonden. And Tenterden too perhaps.I believe that is the case, I remember East Croydon announcements in the 80s pronouncing it as such.
Separately, how many stations called Newport have there been on the network?
I used to deliver School dinners there, not fun in the snowWitton Gilbert, on the now-closed Lanchester branch.
Both in County Durham
It is perhaps luckly that there was never a railway line built to serve the RAF station at Wyton in Cambridgeshire.
Appledore in Devon is both larger than the one in Kent and a definite holiday destination, so perhaps a fairly likely candidate for an uninformed traveller from far afield. If they were unaware that the one in Kent both existed and had a station (which is highly likely), and that the one in Devon no longer had a station, the "Kent" suffix would hopefully prevent them from ending up there by mistake.Appledore (Kent) is another really odd one that has a county suffix even though there are no other stations with similar names.
That makes Wyton relatively unusual as it was usual practice to name RAF stations after the nearest rail station, to make movement orders easier.
I think Appleford comes into the equation for confusion with Appledore.Appledore (Kent) is another really odd one that has a county suffix even though there are no other stations with similar names.
When I lived there, tickets to/from Hinckley were marked "Hinckley (Leics)" and I was never sure what they were differentiating from, unless it was some long-defunct station elsewhere in the country?
I was going to mention Northwich but it never had a Witton station.And, for what its worth, Witton Albion FC are based on the outskirts of Northwich
Newport-on-Tay as well.Newport (Gwent) and the former Newport (IoW) are perhaps the most obvious.
Presumably Newport (Shropshire) had a station once, seems big enough, and there's a still-extant Newport (Essex) (wasn't that the station for Stansted Airport at one point?)
Isn't there a Newport (Pembrokeshire) as well? Not sure if that ever had a station, though.
Changing focus, in the days of Waterloo International you could in theory get trains, with a change or two, to either Beaulieu Road or Beaulieu-sur-Mer.
Which part of St Pancras? There are trains to Gillingham from both Thameslink and Southeastern platforms.I'm almost sure that the announcements at St Pancras for trains to Medway say Gillingham with a hard G - ie the one in Dorset, rather than with the correct soft G - can anyone corroborate or am I just cloth-eared?
There is. It would be Trefdraeth on a station sign now, but it never had a railway. The end of the narrow gauge part of the Trecwn branch was probably the closest that rail ever got.Isn't there a Newport (Pembrokeshire) as well? Not sure if that ever had a station, though.
I once went to the ticket office at Surrey Quays and asked for a ticket to “Witham,” [which doesn’t have a suffix on the ticketing system] and the clerk actually issued me a ticket to Witton (West Midlands).Yes, but when you go to a ticket office and ask for a return to Witton, Whitton or Wyton, how does the ticket clerk know which one you require a ticket to, without needing some clarification.
Southeastern.Which part of St Pancras? There are trains to Gillingham from both Thameslink and Southeastern platforms.
