Anetos
I know that HS2 is designed for 225mph trains which is pretty fast, but what about practically on existing rail infrastructure?
There's a reason why HS1 was built and HS2, in its truncated form, is being constructed.I know that HS2 is designed for 225mph trains which is pretty fast, but what about practically on existing rail infrastructure?
I suspect thats the case, my understanding is the HST was able to acheive similar braking distances at 125mph to a conventional loco hauled service at 100mph. So actual infrastructure changes were fairly minor. Diesel powered, so no power pick up issues. This was why is was a success, a step change in improvement in journey times, with no major infrastructure upgrades.Is it just because BR specified HST as a 125 mph train and thats been cast in stone?
SR suburban area default speed limit is 60 (there are some 70 sections) , otherwise 90 (where permitted), the change used to be at South Croydon.When Southern trains bound for coastal resorts arrive a few minutes late on Platform 3 of East Croydon, the drivers will take it easy to Stoats Nest Junction, accelerate to Star Bridge, then use the welded rail of the Quarry Line to push their 8-coach 377s up to line speed to make up time to Gatwick and then to HHE. Is line speed on the Quarry Line 70mph? The houses and countryside flashed by on my last journey to Eastbourne
It is 90mph.SR suburban area default speed limit is 60 (there are some 70 sections) , otherwise 90 (where permitted), the change used to be at South Croydon.
I would expect the Quarry to be 90, but don't have the sectional appendix to hand.
