The closure is mooted for the Bradford Interchange bus station, which has just been closed for a year due to structural problems. The Combined Authority have recently put out a tender for a business study to decide what, if anything, replaces it.
The railway station isn’t affected. Indeed, the railway station predates the bus station, being built several years before the bus station as a replacement for the old Exchange station. When it opened it was even called Bradford Exchange.
People who bang on about tunnelling between Interchange and Forster Square are the sorts who look at a map and think it must be easy. Anyone who knows Bradford knows it won’t be. Tunnel underneath Forster Square and all you will get is wet feet because there’s a culverted river right where the crayonistas would put their tunnel and their central station.
It isn’t, because it’s not intended to replace the city centre stations, it is intended to be on Northern Powerhouse Rail. Clearly they don’t want that being tunnelled through the city centre so want to keep it off to one side.
And given that I’ve got more chance of marrying Keira Knightley than I have of seeing Northern Powerhouse Rail ever getting built…
Whilst it's claimed to be part of 'Northern Powerhouse Rail' this proposal is essentially a station as part of the existing rail network connected into it. NPR for some sections will merely be NPR services upon existing lines. The 'in full' version of NPR 'some' Bradford politicans are calling for involves an underground station for Bradford. Due to the track curvature of the proposed station will result in the existing interchange station having to be closed! So yes actually quite bonkers!
The pragmatic solution would be to construct a South to North East chord across where St Dunstans used to be then to build a new through station below Wakefield Rd.h That way the existing interchange wouldn't have to close and Grand Central would be able to remain.
Crossing Bradford wouldn't be a bad idea either although it would require a long viaduct, the trouble is when crossing Bradford is mooted the conversation is usually about North to South, but if it went West to North through the St James site then you could extend BFS terminators to Leeds. Yes it would have to go over the back of The Broadway shopping centre which is single storey and would probably warrant that part of be rebuilt but the centre could remain operating as it is at present minus a few shops in the short term.
With a North to East chord you could
run Carlisle and Morecambe services through Bradford and even freight services too. Couple that with the Wortley curve and you got more capacity between Leeds and Shipley junction. Who knows you could potentially even have SELRAP trains through Bradford if Skipton to Colne was reopened.
