How did the original Glasgow Cable Subway work?
PaxmanValenta
11 Apr 2015
Originally the Glasgow Subway was a cable operated Subway with the rolling stock being hauled along the rails by a cable.
How did the trains stop at stations if they were attached to a moving cable?
How fast did the trains travel?
How was braking achieved seen as electricity is needed to power a motor to generate an air or vacuum brake system?
How was electricity supplied for lighting inside the carriages since there would not have been a third rail or overhead electric supply and surely batteries would not have lasted long?
Thanks
The operator simply detached the grip from the cable and apply the brakes. To set off again, the grip was reattached.
I am sure someone else can answer the remainder of the questions!
61653 HTAFC
18 Dec 2012
Don't know about the rest, but I think the lighting would be oil or gas. Not something anyone would entertain today!
sng7
22 Oct 2013
Edinburgh
One thing to note was that all the stations where island platforms hence the doors on one side and they where all built on a hump to help the trains slow down to stop and then accelerate again.
Adlington
3 Oct 2016
When the grip catches the cable, the train runs at the cable speed, downhill or uphill.
hexagon789
2 Sep 2016
Yes, but a train attaching will slow down the cable. The train setting off downhill would mitigate that.
The drivers or gripmen were supposed to gently tighten the gripaper teeth onto the cable to ensure a smooth pickup and starting away without a jolt. As the platforns themselves are on the level the trains wouldn't be on the downhill until out of the station but the downhill stretches would help the trains reach cable speed quicker as the grip man eased onto the cable.
The side rails with T-irons for the lighting survived into electrification days, the original trains simply hadon't traction motors added to make them electrically powered and this archaic arrangement lasted until the refurbishment in 1977-80.
The lighting rails also acted as a communication device, drivers of broken down trains would rub a short-circuiting bar against the rails and this would set off a warbler and open the circuit breakers at the next substation, the driver would then attach a phone to the wires on the wall and could then telephone along to the next station.
I'm not 100% certain what braking was employed in cable-haulage days but the original electrified trains used the single-pipe air brake. It's seems likely that this was used originally either with compressors powered by the lighting circuits or by topping up the air at intermediate stations as was done at terminal stations on the Waterloo and City in the early years.
rebmcr
15 Nov 2011
St Neots
With a cable speed of 15mph, would a simple handbrake not have sufficed?
