How Deep is the Tube?
Mcr Warrior
8 Jan 2009
Is the "deepest tube line" the one which is the deepest below sea level (Jubilee line at Waterloo?), or the one which is the deepest below the local ground level (Northern Line at Hampstead?), or, indeed, somewhere else? :?:
It is up to the person defining the question, but usually the question refers to the depth as measured against ground level, rather than sea level.
The ground level at the buffers at Ongar? ;) (I'll get my coat..)
Horizon22
Jobs & Careers
8 Sep 2019
Very interesting - I've always wondered how steep some sections are, especially for areas that are above ground and then only 10-15 minutes later you're in the depth of a tunnel.
Caboose Class
27 Aug 2021
YORK
This thread got me thinking (and Googling) about the depth of other underground systems in the world. Here are the results:-
CountryCityStationDepth (m)
UKLondonHampstead58
Hong KongHong KongHKU70
USAPortlandWashington Park79
RussiaMoscowPark Pobedy84
ChinaChongqingHongtudi94
UkraineKievArsenalna106
North KoreaPyongyangYonggwang?110?
Horizon22
Jobs & Careers
8 Sep 2019
UKLondonHampstead58
Guessing this is relative depth as opposed to absolute then?
Mikey C
11 Feb 2013
Anyone else now got the Bee Gees song stuck in their head?
"How deep is the tube, how deep is the tube, I really need to know" :D
EC Traveller
28 May 2019
Mainly up and down
Very interesting (from an occasional pax point of veiw).
My question, to tube drivers; do you feel those gradients all day - thinking uphill would be more noticeable, but offset by local rises/falls and the stations themselves.
Taunton
1 Aug 2013
Is the DLR at Bank further below sea level than the furthest below Underground, the Jubilee at Waterloo? It always seems a long way further down from the Northern Line platforms.
I wonder what constitutes ground/street level at Highgate, where you go a long way down from Archway Road into a cutting while still outside. Is it to the street exit from that long outdoor escalator?
jopsuk
13 May 2008
ooh good question- and with other systems, are there stations similar to the (mainline) station in places such as Sanremo in Italy, where the line is underground but the station entrance is about the same height above sea level as the platforms?
Taunton
1 Aug 2013
Strangely, I thought of San Remo in Italy as well, along with Monaco just along the line the same. Both previously had the main line running along just above the seashore at the base of the cliffs, but with urban development all around were moved to new tunneled routes, with underhround station, somewhat inland. The line is obviously still at the same level above the sea, and both have somewhat level passage access to the platforms, but the distance below ground level at the point of the platforms must be substantial.
Lee_Again
29 Sep 2007
Stevenage
Thank you.
I presume it is your own work? Impressive!
Not mine. Just a link to a public website. I've no idea who created them. I'm sure the site will contains details of the author. They are great though.
I think the generally accepted measure is based on how much dirt you'd have to dig through to reach the surface (from the tunnel). I'm sure there are lines nearer the centre of the earth than Hampstead, after all, it's under a hill, but that's hardly a useful definition. Otherwise, if in a hole, you could be the deepest and in fact only be 1m under the surface, or indeed, not under the surface at all!!!!
Taunton
1 Aug 2013
If Hampstead is the deepest current station, then how deep is Bull & Bush, up on the hilltop beyond? *
I always thought that from Hampstead the ground rises steeply to that point, then falls right away again down to Golders Green. Yet these diagrams show that Hampstead to Golders Green is apparently the steepest gradient on the Underground.
* : Edit - I've just found out. It is deeper, but not by much; 221 ft vs 191 ft. Useful diagram here :
Bull & Bush Underground Station (underground-history.co.uk)
cambsy
6 Oct 2011
I think the diagrams of Daniel Silva are really great, but an explanation of the figures, and how to use the diagram, would be useful, i dont know wether i have missed the explanation, or its not on the downloadable pdf, but if there is a guide, could a link etc but put in this thread? Thanks
Egg Centric
6 Oct 2018
Land of the Prince Bishops
UKLondonHampstead58
While not entirely related, should anyone else be wondering "how do I go deeper underground without much hassle" the National Mining Museum will get you deeper than any of these and you'll have a great time too - loved the tour I took a couple of months ago
Neither compare to e.g. gotthard base tunnel though of course.
Lee_Again
29 Sep 2007
Stevenage
Maybe posted before (sorry) but if not, knock your selves out with this...
Tube Depths
Source: https://www.dansilva.co.uk/down-underground
I’ll try…
The number represent the number of meters under street level, the + sign indicates an above surface value.
The < and > signs indicate a direction if the line splits and goes to different depths.
The seemingly random coloured circles represent other tube lines with the numbers again representing depths.
It’s worth noting the lines joining the stations are not a true reflection of the track profile. They simply join the stations. Rise and falls are effectively averaged away!
Busaholic
7 Jun 2014
The North Korean system may well be transporting workers from one part of an underground missile site to another well out of view of any passing satellite! :)
